AEM fuel rail leak?!
I have a brand new AEM fuel rail just installed by veteran of course, on the left side of the fuel rail where fuel comes from there is a slight a leak, moisture of gas seaps out, and on the other side as well where the plug is, theres also a slight leak, installed exactly what the instructions says, can you possibly use locktight/threadlock or some type of sealant to prevent the leakage?!?. HELP!!
yes he is, he actually solved the problem now with the leak, just only problem is with the fuel line, the two bolts that sandwich each other, that started to release some very slight moisture, no dripping, dont know what to do there now. ?
