GSR won't start Im STUMPED!
Old May 7, 2006 | 04:01 PM
import810's Avatar
Default GSR won't start Im STUMPED!
Edit: here is a video of what it sounds like
http://media.putfile.com/Integra-GSR-STRUGGLE
Also would the valves being out of spec cause the car not to start at all?
Earlier this month I did a fresh head rebuild w/:
OEM headgasket
CTR cams w/ ITR valvesprings
New valveseats
Skunk2 IM
ARP head studs
I put it all together and it just wouldn't start. It sounds like it wants to start and if I give it a little gas it sounds like it wants to start a little mroe but still wont
I have checked:
Battery
Spark Plugs + Wires
Fuel Injectors
Timing
all belts
My next step will be compression but I dont have a tester. Any ideas
P.S. Is there anyone around the pleasanton, dublin area that can help me w/o towing it to a mechanic.
Modified by import810 at 5:22 PM 5/7/2006
Modified by import810 at 9:13 PM 5/7/2006
Old May 7, 2006 | 05:23 PM
trini-gsr's Avatar
Default Re: GSR won't start Im STUMPED! (import810)
doublecheck the timing
Old May 7, 2006 | 05:25 PM
import810's Avatar
Default Re: GSR won't start Im STUMPED! (tnt-gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnt-gsr &raquo;</TD></TR><TR><TD CLASS="quote">doublecheck the timing</TD></TR></TABLE>
I will do that but could a bad valve adjustment cause the car not to start?
Old May 7, 2006 | 05:34 PM
Nors's Avatar
I know on older engines it can. Not sure about honda/acuras
Old May 7, 2006 | 07:43 PM
blkb18's Avatar
the valves would have to be way out of adjustment (too tight), holding valves open when they should be closed.
Old May 7, 2006 | 09:52 PM
b16g1teg's Avatar
Default Re: GSR won't start Im STUMPED! (blkb18)
check whether ur injectors are firing in order or not??? also check spark on the distributor then move forward
Timing needs to be checked first
Old May 7, 2006 | 09:54 PM
Acurazor's Avatar
When I put my motor together it wouldn't start because the valves were out of adjustment. I had just got the head back from the machine shop and none of the valves were even opening at all. Did a valve adj, and vroooooooom. Try it, it can't hurt.
Old May 8, 2006 | 01:48 PM
import810's Avatar
Default Re: (Acurazor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acurazor &raquo;</TD></TR><TR><TD CLASS="quote">When I put my motor together it wouldn't start because the valves were out of adjustment. I had just got the head back from the machine shop and none of the valves were even opening at all. Did a valve adj, and vroooooooom. Try it, it can't hurt.</TD></TR></TABLE>
ok but in my helms it says turn the adjusting screw until you feel slight drag???? how slight?
Old May 8, 2006 | 08:17 PM
GOLDBERG's Avatar
Default Re: (import810)
a decent drag.. little looser than cant go through at all.. but u shouldnt have too force it through.. just a nice drag..
Old May 8, 2006 | 08:47 PM
B18ceed's Avatar
check ur map and tps sensors! i had similar problems my tps sensor needed to be recalibrated.
Old May 9, 2006 | 08:40 AM
qfast817's Avatar
Default Re: GSR won't start Im STUMPED! (B18ceed)
check the ignition ground.
Old May 10, 2006 | 10:54 AM
Acurazor's Avatar
It wouldn't even crank if IGN gound wasn't good.
Old May 10, 2006 | 01:16 PM
import810's Avatar
ok the car is running.... what was wrong idk timing or valve adj.
The car's valves tick bad and wont of my adj. screws wont move I have tried like everything So idk what to do.
Old Jun 21, 2006 | 12:32 PM
itr1244's Avatar
ok. i have exactly the same problem here.
car sounds like just like yours and it will only start if i give enough gas
i have these other problem
-[ i can hold/pump the throttle to have my car running] (using my stock ECU)
- i can hold/pump the throttle to have my car running for few seconds and it dies out and the light in my ecu blinks as my PGM-FI relay(under the dash, fuse box) kicks in
i am not trying to hijack your thread but i really need help now too
so did you get your car to start/idle yet?
Old Jun 21, 2006 | 12:49 PM
reno96teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by import810 &raquo;</TD></TR><TR><TD CLASS="quote">ok but in my helms it says turn the adjusting screw until you feel slight drag???? how slight?</TD></TR></TABLE>
just enough so that the very next feeler gauge in size cannot fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by import810 &raquo;</TD></TR><TR><TD CLASS="quote">my adj. screws wont move I have tried like everything So idk what to do.</TD></TR></TABLE>
i apologize if this is a stupid question, but you are loosening the locking nuts, right?
Old Jun 21, 2006 | 01:08 PM
Fat Chick Magnet's Avatar
thats what my car sounds like when i pull out the ecu fuse...you didnt pull any fuses out did you?
Old Jul 25, 2006 | 12:28 PM
DusdmCgsr2's Avatar
Default Re: (dc2rtek)
I'm having the same problem... everything turns over but there is no cumbustion... many people have told me to check my timing and valve lash... and do a compression test before a valve adj.
bonestock92si
38
Aug 30, 2004 10:02 PM
b18c1eg2
Aug 21, 2004 12:28 AM
98Psi ITR
May 27, 2002 11:09 PM
KooK
Apr 12, 2002 08:27 AM
