Head torque specs?
Old May 7, 2006 | 02:51 PM
ludesrv's Avatar
Default Head torque specs?
SOHC ZC (D16A6).
I need confirmation before I go ahead and do it...
72ft/lbs? I think the sequence (I have the bolt sequence, not the torque sequence), it's 22ft/lbs, then 72ft/lb, then 72 again?
Old May 7, 2006 | 02:54 PM
98lude-t's Avatar
Default Re: Head torque specs? (ludesrv)
i just looked and im coming up with 22 then 49lbs
Old May 7, 2006 | 02:56 PM
doubleA's Avatar
Default Re: Head torque specs? (98lude-t)
hmm, 72 is a little high. Take the torque spec, brake it down into thirds and torque from the middle out in a circular pattern
Old May 7, 2006 | 02:58 PM
ludesrv's Avatar
49? Isn't that a little low for a head? I mean, I've torqued down other heads to 72 before with no issues. Wasn't a honda tho, was some POS mazda. Mazda sucks.
Old May 7, 2006 | 03:01 PM
98lude-t's Avatar
Default Re: (ludesrv)
i happen to have a manual right next to me 49 aint low unless ur going head studs and boost its fine remember aluminum pull out easy i do mine to 55
BrightRedOne
Oct 24, 2004 09:45 AM
