clutch vibration while engaging only below ~1800-2000 rpm
Old May 7, 2006 | 01:52 PM
YasRex's Avatar
Default clutch vibration/chatter while engaging only below ~1800-2000 rpm
My new clutch (300 miles) is vibrating while engaging. Its pretty pronouced but only when i take off very slow at low rpms, like in reverse. Normally I take off at about 1800 rpms and it doesnt do it then. IIRC it just started doing this.
Its a standard exedy clutch.
My thought is that I over-greased the input shaft, which i didnt think i did. I used a spare mainshaft to lube the clutch splines and just rubbed in a tiny bit in the splines of the input shaft to aid installation.
Or I may have used the wrong grease and it melted going on to the friction surface. I used black moly.
If I didnt follow the actual installation correctly by not torquing right or not aligning right I think I would have had this problem from the start.
I hope its just breaking in but I'm pretty sure I'm not that lucky.
Any thoughts?
Modified by YasRex at 7:47 PM 5/7/2006
Old May 7, 2006 | 02:06 PM
Elevorett's Avatar
my clutch chatters a ton. Mostly because it's a 6 puck. I didn't re-surface the face of my flywheel, did you? That is almost 100% your issue if you didn't re-surface it.
Old May 7, 2006 | 02:42 PM
YasRex's Avatar
Default Re: (Elevorett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elevorett &raquo;</TD></TR><TR><TD CLASS="quote">my clutch chatters a ton. Mostly because it's a 6 puck. I didn't re-surface the face of my flywheel, did you? That is almost 100% your issue if you didn't re-surface it.</TD></TR></TABLE>
Actually you'll laugh at this. It was a brand new flywheel and I had it resurfaced anyway. Actually it wasn't that flat around the edges of the friction surface.
Old May 7, 2006 | 02:45 PM
ludesrv's Avatar
If it was brand spanking new I wouldn't of machined it. Some clutchs take a bit to break in aswell. Keep driving it, it might take a bit to break in.
Old May 7, 2006 | 03:06 PM
Chiovnidca's Avatar
Default Re: clutch vibration while engaging only below ~1800-2000 rpm (YasRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YasRex &raquo;</TD></TR><TR><TD CLASS="quote">
Organic or puck style disk?
Old May 7, 2006 | 05:41 PM
YasRex's Avatar
Default Re: clutch vibration while engaging only below ~1800-2000 rpm (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Organic or puck style disk?</TD></TR></TABLE>
standard oem replacement, not organic not puck. it does have the same style as the organic just a different part# for pressure plate and clutch disc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">If it was brand spanking new I wouldn't of machined it. Some clutchs take a bit to break in aswell. Keep driving it, it might take a bit to break in.</TD></TR></TABLE>
It was a cheapie chrome-moly lightened flywheel (got it on a technicality, paid $1.99) so I had it done and I'm glad looking at the results. And I agree, the plan right now is to drive it for a while.
One other thing that I didn't mention is that the flywheel and clutch are the 92-00 civic 212mm models. Not the stock 200mm that came on the CRX.
Anyone else?
Modified by YasRex at 6:58 PM 5/7/2006
Old May 7, 2006 | 07:19 PM
Jonathan_ED3's Avatar
It being a 92+ flywheel shouldn't matter.
What do you mean by vibration? are you getting vibration that you can feel only in the pedal; or are you getting vibration that you can feel in the chasis and not in the pedal? Or a combination of both?
Old May 7, 2006 | 07:58 PM
b16civster's Avatar
Default Re: (Jonathan_ED3)
i got a sprung 6 puck w/ a 8.8lb flywheel at it chatters MOST of the time it is also a exeddy i love it it grabbs like a mo fo
Old May 7, 2006 | 10:30 PM
YasRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 &raquo;</TD></TR><TR><TD CLASS="quote">It being a 92+ flywheel shouldn't matter.
What do you mean by vibration? are you getting vibration that you can feel only in the pedal; or are you getting vibration that you can feel in the chasis and not in the pedal? Or a combination of both?</TD></TR></TABLE>
Good question. It feels like the whole front end of the car is shaking, vibrating the dash.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16crexster &raquo;</TD></TR><TR><TD CLASS="quote">i got a sprung 6 puck w/ a 8.8lb flywheel at it chatters MOST of the time it is also a exeddy i love it it grabbs like a mo fo </TD></TR></TABLE>
Old May 8, 2006 | 07:16 PM
YasRex's Avatar
Default Re: (YasRex)
Any ideas?
Old May 9, 2006 | 07:18 AM
It sounds to me like it's chattering. I'd say just keep on driving it and hope it wears away. New clutches are weird sometimes man.
Old May 9, 2006 | 07:36 AM
D16SohcVtec's Avatar
Default Re: clutch vibration/chatter while engaging only below ~1800-2000 rpm (YasRex)
Probably just chattering like a few as said here. I remember when I had my 6-puk unsprung hub. Everytime I popped the clutch all my pennies in the little pocket would go flying out always thought something broke.
Old Oct 25, 2009 | 11:44 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
bump from the dead, my clutch does this too, i've been through two sets of clutches, flywheels, and trannys.. what could be the problem?
jdmstyleEJ6
12
May 9, 2010 04:13 PM
an2ny888
Aug 25, 2007 03:11 PM
xunkn0vvnx
Mar 9, 2005 01:47 AM
Stock@$$GSR
Dec 16, 2003 03:05 PM
Beave0101
Mar 23, 2003 08:36 AM
