swapped ef alternator removal??
Old May 7, 2006 | 10:20 AM
HU MAN CHU's Avatar
Default swapped ef alternator removal??
i cant get my alternator out of the car, i took off the mounting brackets that hold it and dont have enough clearance to get it out either up or down, anybody have the same problem, what will be the easiest way to get it out, so far all ive heard is that i have to remove the manifold, but dam...
Old May 7, 2006 | 10:39 AM
1C9R9X1's Avatar
Default Re: swapped ef alternator removal?? (HU MAN CHU)
YEA, 1 OF MY FRIENDS SAID TO UN BOLT AND MOVE THE MASTER CYLINDER,IV NEVER DONE IT LIKE THAT BUT HE SAID IT WAS "EASIER" CHECK IT OUT SEE WHAT HAPPENS
Old May 7, 2006 | 10:58 AM
HU MAN CHU's Avatar
Default Re: swapped ef alternator removal?? (1C9R9X1)
if i remove the cylinder will i have to purge my brakes, how easy is it to do?
Old May 7, 2006 | 11:03 AM
IO_303's Avatar
I just pull the fuel rail and at the right angle it will barely make it out.
Old May 7, 2006 | 03:37 PM
Black4thgenEF's Avatar
Default Re: (IO_303)
I pop the axle out. works well.
Old May 7, 2006 | 03:50 PM
Crx Jimmy's Avatar
you can pull the axle which i did , and if you move the master leave the lines on just remove the 2 bolts from the brake booster you should be able to move it a couple inches then with the lines on, i have never done this to remove an alternator but its worth a try
Old May 7, 2006 | 04:19 PM
98lude-t's Avatar
Default Re: swapped ef alternator removal?? (Crx Jimmy)
undo motor mount and lift motor up
or down
Old May 7, 2006 | 09:53 PM
HU MAN CHU's Avatar
THANKS FOR THE IDEAS, I WENT WITH THE FUEL RAIL, EASIEST TO REMOVE AND HAD ENOUGH SPACE, ALSO I CAN UPGRADE THE RAIL WHILE IM AT IT THANKS...
Ef4doorwagon
Jun 15, 2014 06:04 PM
rivoe302er
Jun 17, 2008 07:20 AM
tigueremalo
18
Jun 2, 2007 11:41 PM
Jeff
14
Oct 19, 2005 12:02 AM
'88civic
Nov 3, 2002 06:51 AM
