Removal of 2 stripe...
Old May 7, 2006 | 07:47 AM
STYLiNxCHiQ_DA9's Avatar
Default Removal of 2 stripe...
I recently just bought a 91 Integra LS and just for a future note base on repainting ...
What's the best way to remove the 2 stripes that runs from rear to the front fender side sticker? (Not that I want to remove it, just nice to know for repainting purpose later on) Is there anyway to do this without harming the clear coat/paint itself?
What I noticed is that, I'm not 100% sure if the stock sticker is Black color, but mines is a little dark blue but little portion of the blue is stripping off which then lays a black layer on it, Was the black layer the original color?
Thanks in advance
Old May 7, 2006 | 07:51 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Removal of 2 stripe... (STYLiNxCHiQ_DA9)
Pin stripes are a dealer add-on.
Old May 7, 2006 | 07:54 AM
That answers my second part of the question what about the best way to remove that without harming the clear coat?
Old May 7, 2006 | 08:05 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Your finger nails? that's how I took mine off.
-Todd-'s Avatar
Use a blow dryer and peel them off, it will leave a little sticky stuff behind. I forgot what I bought to remove the adhesive tho.
Old May 7, 2006 | 08:16 AM
Usagi Yojimbo's Avatar
From: Dont say my car is topless say the titties is out
Default Re: Removal of 2 stripe... (-Todd-)
Try a razor blade and get under it enough to peel it off
Old May 7, 2006 | 08:28 AM
arrojj's Avatar
Default Re: Removal of 2 stripe... (Usagi Yojimbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Usagi Yojimbo &raquo;</TD></TR><TR><TD CLASS="quote">Try a razor blade and get under it enough to peel it off</TD></TR></TABLE>
HAHAHA I hope your kidding with that razor blade idea
But wait for a really hot day and that should aid you on peeling it of with your finger nails, thats how i did mine i was at the mall and got the great idea to do it then security comes up askin 21 questions.
Old May 7, 2006 | 08:35 AM
-Todd-'s Avatar
wow razor blade is a no, you can use your finger nail most of the time to peel the ends up. Im telling you, use a hair blower heat up the pin strip and it will peel off.
Old May 7, 2006 | 08:44 AM
iheartDc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Todd- &raquo;</TD></TR><TR><TD CLASS="quote">Use a blow dryer and peel them off, it will leave a little sticky stuff behind. I forgot what I bought to remove the adhesive tho. </TD></TR></TABLE> yeah thats a good way to do it, you should use GOOGONE it removes any kind of adhesive, and helps out by not harming the paint.
Old May 7, 2006 | 09:29 AM
vinai's Avatar
Default Re: Removal of 2 stripe... (iheartDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartDc2 &raquo;</TD></TR><TR><TD CLASS="quote"> yeah thats a good way to do it, you should use GOOGONE it removes any kind of adhesive, and helps out by not harming the paint.</TD></TR></TABLE> thats how I did it on my DA
Old May 7, 2006 | 09:53 AM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
Default Re: Removal of 2 stripe... (vinai)
I have a red integra and I tried taking mine off, it left a black line from the adhesive or what not? anyway to get rid of?
Old May 7, 2006 | 09:57 AM
Good information on the part about heating up the stripe with a blow dryer.
But it seems like the black adhesive isn't going to be easy taking off.
Some of the blue top sticker is peeling off which leaves me to see black adhesive sticking on fine.
EDIT:
Where might I be able to get GOO GONE at?
Is there any local stores that sells it? Or would I need to order it online o.O
Old May 7, 2006 | 10:24 AM
ThaLost0ne's Avatar
you can get GOO Gone at home depot..
Old May 7, 2006 | 11:06 AM
The_Ricky_Is's Avatar
Default Re: Removal of 2 stripe... (FckTheives)
i waited for a hott day an took my finger nail too it. then i went over it with some goo gone
Old May 7, 2006 | 01:42 PM
JoePSI's Avatar
Default Re: Removal of 2 stripe... (The_Ricky_Is)
This is how i got mine off... Put the goo gone on, let it sit 5min. Get a blow dryer and a plastic putty knife. Heat the pin stripe up at the back where it meets the hatch and gently push it up with the putty knife. I did mine in sections because the goo gone kept running and drying up.
Old May 7, 2006 | 04:07 PM
Newkdog's Avatar
I miss Andrea.
Lose that gold whatever the hell that is as well while you're at it!
Jedimiah
Nov 16, 2006 11:47 AM
PAC_MAN
Honda S2000
14
Sep 23, 2005 11:18 AM
uranazo
12
Nov 8, 2003 01:17 AM
ImportHatch
Jul 23, 2002 11:42 AM
