crx door panels how to remove
Old May 6, 2006 | 11:56 PM
supracrx's Avatar
Default crx door panels how to remove
ok i know there are screws...only problem i have is taking the manual window roll down handle...how does it come off? i know there is some kind of spring or clip but how? any suggestions or tips?
reason i'm taking it off....my co-worker backed up into my door and now there is a dent....i'm gonna see if i take the panel off would i be able to just knock it back out slightly.. this ******* blows...i just bought new tires for my SI wheels, got suspension and almost had my stero hooked up and everything in the car was done and now this happens...this sucks
Old May 7, 2006 | 12:36 AM
JJ's civic's Avatar
Default Re: crx door panels how to remove (supracrx)
push the panel back and you should be able to see the clip use a flathead screw driveer and you should be able to pull it out. to put it back on jsut put the clip back into the **** opart before puting back on the door. (my first real tech post
Old May 7, 2006 | 06:32 AM
baconcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supracrx &raquo;</TD></TR><TR><TD CLASS="quote">ok i know there are screws...only problem i have is taking the manual window roll down handle...how does it come off? i know there is some kind of spring or clip but how? any suggestions or tips?
reason i'm taking it off....my co-worker backed up into my door and now there is a dent....i'm gonna see if i take the panel off would i be able to just knock it back out slightly.. this ******* blows...i just bought new tires for my SI wheels, got suspension and almost had my stero hooked up and everything in the car was done and now this happens...this sucks</TD></TR></TABLE>
Well, to take it off, you need a rag and some needle nose plyers. you turn the window crank into the down position and then pull out on it with the rag, and up between the handle and the door theres a little clip.
But i took my door panels off last week, and theres another metal piece between the panel and the outside of the door, and i think that they're welded together. But, good luck
Old May 7, 2006 | 06:37 AM
pinecone's Avatar
Default Re: crx door panels how to remove (baconcrx)
For the door dent, see if you can't pull it out with a plunger, unless it is bad and paint is chipping. I pulled a dent out of my front fender with my plunger
Old May 7, 2006 | 09:21 AM
supracrx's Avatar
nope didn't work with plunger....no paint scratch at all just the dnet but the molding is holdiojn it back
Old May 7, 2006 | 08:43 PM
JJ's civic's Avatar
Default Re: (supracrx)
jsut push on the door panel and your see the little clip just pry it out with a screw driver i just did it the other day
Old May 7, 2006 | 09:22 PM
supracrx's Avatar
panel took off and still couldn't pop it out...the two beams in the way so yea...
guess i gotta go to body shop
Gremlin_rex
Nov 15, 2011 06:28 AM
Cowiebunga
10
Nov 27, 2007 01:33 PM
todd.ludwig
May 1, 2006 02:27 AM
[HrZn]4life
Feb 11, 2003 01:21 PM
Thrillhouse
Apr 14, 2002 11:30 AM
