[Dyno] USDM ITR motor + Skunk2 Pro 1 Cams
USDM ITR Motor
1.8L Hytech Header
AEM CAI
Skunk2 Pro 1 Camshafts
Kteller 2.5" Exhaust
Supertech Flat Face Valves
Buddy Club 0.4mm Head Gasket
Lucas 310cc Injectors
Tuned to a conservative 13-13.5 A/F
Cam Gears are left at 0/0
comment/suggestions
1.8L Hytech Header
AEM CAI
comment/suggestions
Not so much. I went with the Pro 1s because I saw a lot of people having great results with them. I also got a very good deal on them as well.
sure it wasnt sk2 stage 1 cams? there should be way more power everywhere, so the cams may need gear tuning but something doesnt seem right. How does the car idle? if its not on the lumpy side you may have non-pro1 cams.
I edited my post. The Pro1's aren't all hype, this thread just caught me at a bad time. Obviously the cams make power, they just may not suit this particular motor well. Keep pushin it bs, she's got more power in her.
Modified by clean rice at 8:15 AM 5/18/2006
There is more in the motor. Cam gear tuning, VTEC x-over, ignition timing maps. Something looks amiss. Both graphs have a dip at about 6,500; the question: why?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">There is more in the motor. Cam gear tuning, VTEC x-over, ignition timing maps. Something looks amiss. Both graphs have a dip at about 6,500; the question: why?</TD></TR></TABLE>
i agree there has got to be more power somewhere. my stock jdm gsr w/ skunk2 mani, stock header, intake, tuned on S200 made 175/135......
i dunno, just my .02
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan »</TD></TR><TR><TD CLASS="quote">maybe they're not pro1's and in fact stage 1's.</TD></TR></TABLE>
Umm look at the pic above.. Yes they ARE pro1s and yes they are stage 1s
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Tech »</TD></TR><TR><TD CLASS="quote"> Yes they ARE pro1s and yes they are stage 1s</TD></TR></TABLE>
what?
what?
Doesn't look like the engine was tuned 100%. There is a pretty big dip when vtec crosses over and another dip around 4000-5000. If it is tuned go to a different tuner. Also what did you use to tune it with?
The 1hp peak gain can be lived with if the area under the curve is fatter, which it doesnt look like it is.
How does the car idle with so much overlap? Usually with the pro1's one of the cams is retarded to reduce the overlap. But i agree with the lot here in that more tuning is needed to take advantage.
yea definately something doesnt look right, when i had my itr cams in my build and switched to Skunk2 Stage 2's i noticed a great difference from 6.5k all the way to 9.4k but i had a great ECU to go with it. are these SKunk2 Pro 1's like **** then???
i agree with the tuning. did you degree the cams in? were they swung on the dyno? the vtec crossover needs to be tweaked. It looks like vtec is set at 6300. Thats a bit high for them. i think 6 might better suit, but it depends on the motor.
Both dips in the graph greatly affect the powerband. get another tuner, or get back on the dyno if there are other circumstances with him that we dont know about
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reddohcvtec »</TD></TR><TR><TD CLASS="quote">About 1 more hp and 2ft/lbs less torque..I think u need a better tuner, and play with the cam gears.</TD></TR></TABLE>
i agree
i agree
