My DA wont start up right away
Old May 6, 2006 | 10:43 PM
ViCtOr VaHn's Avatar
Default My DA wont start up right away
i have a 90 4door with a b16a. It takes me at least 20 cranks to get the car started.when it does finally start, it starts up shaking for a couple seconds, then sounds fine, but when i give it gas it chokes , so i have to let it warm up for at least 5 min before i can drive it. Changed out tps, map, and fuel filter but didnt chande at all. thanks people !
Old May 6, 2006 | 11:16 PM
Noemotion_91DA's Avatar
Default Re: My DA wont start up right away (ef9er323)
I had the same problem with my DA. It turned out to be the fuel pump. You might want to see if fuel is reaching the filter, before changing the pump.
Old May 6, 2006 | 11:42 PM
thanks ! I'll try checking the pump 2morrow
Old May 7, 2006 | 02:17 AM
jdm_bones's Avatar
Default Re: (ef9er323)
When was the last time you changed the fuel filter?
Old May 7, 2006 | 09:35 AM
Default Re: (jdm_bones)
i changed the fuel filter 2 months ago
Old May 7, 2006 | 09:38 AM
lacking vtec's Avatar
don't forget to check ur main relay! i had that same problem a few weeks ago and it drove me crazy. i changed the fuel pump, filter, i cleaned my intake system...EVERYTHING. it turns out it was just my main relay module. worth $60...or if u could resolder it u can.
Old May 7, 2006 | 09:41 AM
Default Re: My DA wont start up right away (RagingAlcoholic)
weres the main relay located
Old May 7, 2006 | 09:47 AM
zhan28's Avatar
starter?
Old May 7, 2006 | 01:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9er323 &raquo;</TD></TR><TR><TD CLASS="quote">weres the main relay located</TD></TR></TABLE>
behind driver's side panel near the fuse box...above ur left knee when u sit down... its in that general area.
Old May 7, 2006 | 05:18 PM
i'll check it out , thanks !
Old May 8, 2006 | 02:38 PM
dc5_integra's Avatar
Have you tried doing just a regular tuneup? Sounds to me like that could be your problem right there. Cant be your starter obviously if it is turning over 20 times and if it was your relay then it wouldn't start at all. Could be fuel pump tho. Good luck
Old May 8, 2006 | 06:40 PM
EG6 ON STANDS!'s Avatar
Default Re: My DA wont start up right away (dc5_integra)
go to the junk yard for the relay and put it in your pocket. just pay $2 for entrance and walk out saving $58.
Old May 8, 2006 | 09:18 PM
solareclipseauto's Avatar
Default Re: My DA wont start up right away (weak16DA)
i had the same problem and after i checked everything it ended up being my regulator. it was not holding enought fuel pressure. i changed it and the car starts right up every time
Old May 8, 2006 | 10:07 PM
themilman's Avatar
I was also going to say check the FPR, you can get them cheap off a forum, heck, I have one, or a junk yard. I'd also check the tune-up parts, plugs, cap, rotor, wires (resistance), etc. You could also remove the EACV from the back of the intake manifold and clean it out. Get a friend and check your throttle response with the car off, maybe your cable is loose or the throttle is sticking? Good luck.
accordexdude25
Sep 7, 2014 07:09 PM
SlowB20z
Apr 28, 2013 07:26 PM
mikester1222
Nov 16, 2008 05:16 PM
lude1888
Jul 22, 2006 03:08 PM
94b18c
Aug 30, 2004 10:21 AM
