Rear Drum Brake Upper Return Spring
Old May 6, 2006 | 07:00 PM
ujhonda's Avatar
Default Rear Drum Brake Upper Return Spring
I am doing my rear drum brakes – yes I removed them and trying to install new shoes, but I can’t get the Upper Return Spring(Big one) on to the shoes – how can I do this?
Please help me I don’t have special tools, just pliers and screw drivers and hammer
I am pretty sure pro mechanics have an easy way around this.
Do I install that crazy spring first or after mounting shoes to the brake plate ?
Thanks in Advance
Old May 6, 2006 | 07:47 PM
YeuEmMaiMai's Avatar
Default Re: Rear Drum Brake Upper Return Spring (ujhonda)
I use a pair of large needle nosed pliars... it works very well
Old May 6, 2006 | 08:28 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Be careful when replacing the return spring, as they are usually very strong. It is recommended to also wear eye protection.
Using a pair of vice grip is safer, that way there is less chance of the spring coming loose, and injuring yourself. (A regular needle nose plier will work, but there is a greater change of the spring coming loose from the plier.)
Old May 6, 2006 | 08:32 PM
Default Re: Rear Drum Brake Upper Return Spring (tech8)
yeah channel locks are good but the ones I have are too large to use and I hook the needle on the end of the spring and pull it to the hole. Works fairly well
Old May 7, 2006 | 05:55 AM
Chiovnidca's Avatar
Default Re: Rear Drum Brake Upper Return Spring (YeuEmMaiMai)
Honda also sell a special tool that lets you you twist them into place, if you do alot of em.
Old May 7, 2006 | 07:24 AM
ujhonda's Avatar
Thanks everyone!
Home Depot long nose vice grip did the job – it was pretty easy to install the spring with vice grip and lot safer. Now I have to bleed all my brake lines, because I pop and drop one of the brake cylinder last night while I am struggling with normal pliars
Now I have to find a 3rd Leg to push the paddle
Old May 7, 2006 | 03:23 PM
buy a 1 man bleeder kit...will save you a lot of time
Old May 7, 2006 | 03:33 PM
Chiovnidca's Avatar
I just use a short piece of hose and a bucket.
Old May 7, 2006 | 03:37 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Rear Drum Brake Upper Return Spring (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">I just use a short piece of hose and a bucket.</TD></TR></TABLE>
, gravity bleeding.
Old May 7, 2006 | 10:37 PM
HONCORD's Avatar
gravity bleed, or use a buddy system. lol.
fragmare
Oct 7, 2012 07:17 PM
imadigitalgod
Sep 5, 2010 02:42 PM
briq4
Honda Civic (2001 - 2005)
May 1, 2010 02:22 PM
thesmogman
Jan 18, 2010 12:30 PM
RCautoworks
18
Jul 30, 2003 02:02 PM
