lsvtec setup with plenty of questions!!
Old May 6, 2006 | 06:40 PM
Devo94ac's Avatar
Default lsvtec setup with plenty of questions!!
Ok so i bought most of this setup already and have been searching everyday for a little over 6 months for my summer lsvtec build and i need some help. Its going in my 94 se.
now for my setup:
stock del sol head
aem cams
ge lsvtec kit
ls head gasket
310cc injectors
aem fuel rail
aem fuel pressure reg.
dc 4-1 header
pr3 rods
stock p30 pistons
new piston rings
new rod bearings - just the ls bearings?
ls block
block girddle - is it needed? what kind to get? i heard Z10 eng.is good?
ls crank - do i need this mirco polished? balanced?
crank case breather kit - is it needed? Z10 eng is good?
uberdata what ecu should i run?
arp rod bolts - what size? 8 or 9mm?
arp headstuds - gsr or ls or b16?
type R pumps or just gsr?
trying for NO port/polish
Old May 6, 2006 | 06:56 PM
Immanuel's Avatar
Default Re: lsvtec setup with plenty of questions!! (Devo94ac)
what do you need help with?
Old May 6, 2006 | 06:58 PM
Devo94ac's Avatar
Default Re: lsvtec setup with plenty of questions!! (1.6 DOHC ED9)
the questions i asked!
Old May 6, 2006 | 07:02 PM
Immanuel's Avatar
OH my fault, I didnt see what you were asking.
Old May 8, 2006 | 06:26 PM
Devo94ac's Avatar
how about some answers!!
Old May 10, 2006 | 10:34 PM
Devo94ac's Avatar
come on someone knows some answers!!!!
Old May 10, 2006 | 11:16 PM
Honda-bond's Avatar
Are you having someone size the bearings and gap the rings? If so, they should supply the bearings (ACL, clevite).
Block girdle probably not necessary, but Honda seems to think its a good Idea.
I like Golden Eagles girdle.
Definitely balance, micro polish and some sort of crack inspection on the crank.
Breather kit, maybe. Don't know what kind is the best.
The p28 ECU is pretty common and works well. Harness jumpers are all over.
ARP head studs come in different lengths?
GSR water pump and oil pump. Is there a difference between b16A and b18C oil pumps?
Why no port polish? Remember, the chain is only as strong as the weakest link.
Old May 11, 2006 | 07:25 AM
SkRiBLaH's Avatar
cant use PR3 rods and a PR4 crank. must use PR4 rods.
Old May 11, 2006 | 06:19 PM
Devo94ac's Avatar
Default Re: lsvtec setup with plenty of questions!! (SkRiBLaH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH &raquo;</TD></TR><TR><TD CLASS="quote">cant use PR3 rods and a PR4 crank. must use PR4 rods.</TD></TR></TABLE>
i was tld differently!
Old May 11, 2006 | 06:29 PM
DC2 Mang's Avatar
8mm rod bolts, ACL LS bearing or OEM B16, ITR and GSR pumps are the same thing, the girdle is unnecessary, and the balance is also unnecessary
Old May 11, 2006 | 06:33 PM
ALLMOTA92EG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devo94ac &raquo;</TD></TR><TR><TD CLASS="quote">
i was tld differently!</TD></TR></TABLE>
You must use the ls rods the pr3's arent long enough
Old May 11, 2006 | 07:48 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devo94ac &raquo;</TD></TR><TR><TD CLASS="quote">Ok so i bought most of this setup already and have been searching everyday for a little over 6 months for my summer lsvtec build and i need some help. Its going in my 94 se.
now for my setup:
stock del sol head
aem cams gears?
ge lsvtec kit
ls head gasket Use OEM
310cc injectors
aem fuel rail Useless, IMO.. Unless you like the bling
dc 4-1 header
pr3 rods Whoever told you this is a moron.. use LS rods. Polish beams & shotpeen (Not necessary), and have the big end journal checked
stock p30 pistons
new piston rings Again, be sure to use OEM
new rod bearings - just the ls bearings? Use B16 bearings.. ACLs and Clevites work great
ls block
block girddle - is it needed? what kind to get? i heard Z10 eng.is good? Not necessary unless you plan on turning a lot of RPMs. This will require you to have your main journals align honed
ls crank - do i need this mirco polished? balanced? Micropolish, yes. If you have the crank balanced, have the rest of the rotating assembly balanced as well.
crank case breather kit - is it needed? Z10 eng is good? Catch can
uberdata what ecu should i run? P28 will work
arp rod bolts - what size? 8 or 9mm? 8mm
arp headstuds - gsr or ls or b16? GSR
type R pumps or just gsr? Type R oil pump is a P72 oil pump, which is a GSR oil pump..
trying for NO port/polish Do it if you can.. </TD></TR></TABLE>
Old May 13, 2006 | 11:03 PM
Devo94ac's Avatar
Default Re: lsvtec setup with plenty of questions!! (LSVT3K 91 C1V1C)
thanks for all the help!!!
95coupeb
26
Apr 28, 2010 07:00 AM
levee000
Sep 4, 2008 03:12 PM
absoluteacura
Jul 31, 2008 08:08 PM
made in JAPAN
Jun 15, 2004 06:54 AM
