Going Turbo is there a big difference between gsr and ls tranny????
Compared to an LS transmission, the shorter, closer gear ratios of the GSR transmission are always better for NA or turbo.
okay if your pushing BIG power then go with the ls transmission because the longer gears will help with traction etc. If your doing just a moderate slap on turbo set up then its your choice but i heard that ls tranny is better for turbo.
Somebody correct me if I'm wrong but 1 and 2 gear are the same in the gsr and ls trannys. Its 3 gear the makes the big difference. Also shorter gears would make the turbo spool faster therefore being better for turbo in my opinion. But like I said correct me if I'm wrong.
Well the b16 tranny is very short geared so traction becomes the problem because the turbo spools to fast and it doesnt keep you in the power band long enough before you shift into the next gear. All this depending on what turbo your running also what size of slicks or tires makes a difference on how fast the tranny pulls you through the gears.
My bro has a 600+ hp turbo hatch and he put in a b16 tranny and pulled an INSANE 60 foot and was on track to run low 10's until he shifted to third and the tranny blew. He had just barely run a 10.4 the run before but with his INSANE 60 foot we know it would have atleast been better then 10.4. So I guess it really depends on personal opinion. These times were faster then any run he did with a gsr tranny.
I think gsr tranny is better for turbo then the ls tranny and that is my final answer.
Modified by b18bme at 4:26 AM 5/7/2006
Modified by b18bme at 4:31 AM 5/7/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bme »</TD></TR><TR><TD CLASS="quote">Somebody correct me if I'm wrong but 1 and 2 gear are the same in the gsr and ls trannys. Its 3 gear the makes the big difference. Also shorter gears would make the turbo spool faster therefore being better for turbo in my opinion. But like I said correct me if I'm wrong.</TD></TR></TABLE>
Actually only first gear is the same. Second all the way through fifth are all longer gears. I know this because i had an Ls tranny and then i switched to a gsr tranny and also HOnda tech says so haha.
And also you are right some people prefer different trannies but from what i heard from people's experiences, they seem to like the LS tranny better. But what the heck if you can pull of better times in a b16 trans then more power to ya
Somebody provide some proof of the ls and gsr tranny ratios. I could have sworn that 1 and 2 are the same between the trannys the final drive is different therefore possibly making second gear feel shorter in the gsr. But I am trying to search for some answers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoppa »</TD></TR><TR><TD CLASS="quote">how big of a difference is there between the gsr and ls tranny? does the ls have much longer gears or pretty close to the gsr</TD></TR></TABLE>
i have a itr tranny and planning on boosting soon.
u never know until u feel it urself
ls tranny suck, close gear is always better. your never gonna go 180 mph all the time on a street car lol. Close gears keeps u in the higher rpm range, which is where honda motors make their power... so duh.. its pratical. Spool time has NOTHING to do with a transmission, its in the motor and turbo size and other characteristics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdssk8rcs1 »</TD></TR><TR><TD CLASS="quote">Spool time has NOTHING to do with a transmission, its in the motor and turbo size and other characteristics. </TD></TR></TABLE>
Well think about it, the faster you moter gets through the gears the faster your rpm's hit redline, it won't make the turbo itself spool faster but makes the motor rev faster because of the shorter gears making the turbo hit full boost sooner. Make sense?
Well think about it, the faster you moter gets through the gears the faster your rpm's hit redline, it won't make the turbo itself spool faster but makes the motor rev faster because of the shorter gears making the turbo hit full boost sooner. Make sense?</TD></TR></TABLE>
No, it makes no sense. If you are waiting for a turbo to spool when the engine is at redline, you made some very poor choices when designing the turbo. Shorter, closer gear ratios are always better. Don't believe me, only use gears 1, 3, and 5; you should have plenty of "spool" time then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bme »</TD></TR><TR><TD CLASS="quote">Somebody provide some proof of the ls and gsr tranny ratios. I could have sworn that 1 and 2 are the same between the trannys the final drive is different therefore possibly making second gear feel shorter in the gsr. But I am trying to search for some answers.</TD></TR></TABLE>
here some tranny specs for you
http://www.hondaswap.com/forum...29829
the first and second gears are the same ratio 3-5 are different
this bs again?? To OP...those claiming that an ls tranny is better for boost have absolutely no clue of what they are talking about...Shorter gears will ALWAYS be better for any racing application...And to those yelling traction sir traction sir....YOU DONT DOWNGRADE YOUR TRANSMISSION TO GET TRACTION, YOU ATTEMPT TO GET BETTER TIRES, TRACTIONS BARS, ETC...Thats the MOST backwards thing ive heard in order to gain traction...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoppa »</TD></TR><TR><TD CLASS="quote">so im better off just sticking with my b16 tranny ya?</TD></TR></TABLE>
Yes. Invest in a good LSD for your transmission.
