Camber Kits...Skunk2 or Ingalls?
Old May 6, 2006 | 05:27 PM
MansuDC2's Avatar
Default Camber Kits...Skunk2 or Ingalls?
I was wondering if any of you DC integras are running on Skunk2 Camber kits and how is it? I've had Ingalls on my other car which was a Accord and to me Ingalls is by far the best, especially when it comes to the front camber kit for the front upper control arm. How safe is SKunk2's front camber kit with the replacement Crontol arm? I know the Ingalls one replaces the anchor bolts, but the Skunk2 camber adjuster ball joint looks like it could come loose and slide.
Old May 6, 2006 | 05:55 PM
KArowd's Avatar
I would recommend the skunk2. They are from what ive experienced since i have them on my teg the best camber kits. Strong and beautiful at the same time. cant get better then that
Old May 6, 2006 | 05:56 PM
PrinceAli132's Avatar
Default Re: (DOughh)
I've been using the Skunk2 for about 1.5 years now and about 20,000 miles and haven't had a problem yet.
Ali
Old May 6, 2006 | 05:57 PM
__oversea's Avatar
Default Re: Camber Kits...Skunk2 or Ingalls? (MansuDC2)
make sure you get updated version.
Old May 6, 2006 | 10:19 PM
MansuDC2's Avatar
Default Re: Camber Kits...Skunk2 or Ingalls? (Most Known Unknown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Most Known Unknown &raquo;</TD></TR><TR><TD CLASS="quote">make sure you get updated version. </TD></TR></TABLE>
The updated ones, you mean the ones with the new goldish flat-top looking ball joints right? Did you eople just get the crontrol arm w/ the adjustable ball joint or did you guys get the one that comes also w/ new anchor bolts w/ urethane or rubber bushings? I think the updated ones are called the Pro-series Plus?
Is this the updated one?
w/o New Anchor bolts
w/ new anchor bolts
Old May 6, 2006 | 10:26 PM
MansuDC2's Avatar
Just worried they will slip or get loose, since its only being tightened by 4 allen head tupe bolts.
Old May 6, 2006 | 10:47 PM
__oversea's Avatar
ya thats the new version. i dont know about 2nd pic. last version had problem with being slipped, because there was no support. (plate on top, where the adjust screws are).
Old May 7, 2006 | 02:49 AM
jdm_bones's Avatar
Default Re: Camber Kits...Skunk2 or Ingalls? (Last For One)
I have the old Skunk2 for about 18 months now, and about 30,000 miles and I've had no problems...I love the way they ride and sit...I wouldn't change them...
Old May 7, 2006 | 03:45 AM
trini-gsr's Avatar
Default Re: Camber Kits...Skunk2 or Ingalls? (jdm_bones)
i've had the old skunk2's for close to 2 years, probably a good 50,000 miles on em. they work great, havent had a problem with slipping yet...
Old May 7, 2006 | 06:42 AM
shorto85's Avatar
Does the new version come with new anchor bolts?
Old May 7, 2006 | 07:29 AM
Robstunner4's Avatar
Default Re: (shorto85)
omnipower is good too
Old May 7, 2006 | 11:06 AM
MansuDC2's Avatar
Default Re: (Robstunner4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorto85 &raquo;</TD></TR><TR><TD CLASS="quote">Does the new version come with new anchor bolts?</TD></TR></TABLE>
Well as far as I've know or have seen, the updated ones can be bought w/ or w/o the new anchor bolts, I guess the stock anchor bolts will do, but I think I might just get the ones w/ new anchor bolts since mine are probably worn, who knows... I heard good news about Omni's as well almost the same design camber kit.
Old May 7, 2006 | 03:43 PM
LsHoney84's Avatar
Default Re: (MansuDC2)
ive been trying to figure out for a long time about which camber kit to get. I guess ill go with the new skunk2
Old May 7, 2006 | 05:01 PM
lalo's Avatar
SKUNK
be.twenty
Apr 1, 2005 12:57 AM
bbarbulo
May 18, 2004 02:26 PM
vtecmike1
Apr 8, 2004 09:52 PM
gribbs
Nov 19, 2003 07:25 AM
2000si
Feb 1, 2002 04:15 PM
