Injector/FPR ???
i have an '86 civic si and i picked up injectors and a fuel pressure regulator from an '89 dohc integra at the junk yard and i was wondering if there is any difference in my injectors and the tegs will i notice any difference with these , if not i only payed $1 so no biggie
thank you
Dan
thank you
Dan
The injectors may work but I think the regulator will make your car run too rich. if honda is using the same injectors in its models (ITR had same injectors as a Dx civic) then the varying component is the regulator. Try to get that from an si with the same motor as yours.
