FS ******Misc Parts***** updated regularily
I am located in st. catharines but willing to meet anywhere is T.O. or wherever.
Best way to get ahold of me is msn crxboy69@hotmail.com or email me
I have pics for all parts so if you want a pic just ask
All parts are OBO
D16Y8 Block - basically everything minus crank disassembled (willing to part out oil pump, water pump, pistons, rods, crank pulley, etc...) $75
Knock Sensor - fits b and d series $30
90-91 CRX Corner lights mint no broken tabs OEM $40
88-89 CRX bumper signal lights $20
D series starter have two $40
B series starter have two also $40
CTR power steering pump $50
sohc vtec power steering pump w/ resevoir $40
Non vtec integra 94+ power steering pump w/ resevoir $40
94+ integra drivers side mount have both pieces $30
B16 oil pan/ oil pickup/ windage tray $40 will work on LS and GSR also with all those parts
PM6 ECU 88-91 CRX/Civic Si OBD0 $30
OBD1 DOHC VTEC oil pump $40
OBD2 DOHC VTEC oil pump w/ CKF sensor $40
SOHC VTEC water pump $30
DOHC VTEC water pump $30
B or D series electric VSS $30
94+ integra rad fan $25
SOME MORE PARTS
99-00 SiR Master Cylinder 15/16 and Prop valve non ABS $70 MINT!!!
4-wire O2 sensors (got 2 or them) $30/each
P73 pistons (Type R) only have 3 i got melted $30
OEM CRX shift **** $10
88-89 CRX taillights I have two complete sets mint $50/each
90-91 drivers side taillight mint $25
D16A6 Cam, Cam Gear, Cam Seal $20
D16A6 intake manifold and exhaust manifold gaskets some other random gaskets $10
MSD Blaster SS coil $20
Ignition coil from B series distributor (fits D as well) $30
Various Throttle Body's workin MAP and TPS sensors $25
B series Pressure Plate came from an B18B $30
LS Flywheel $40
SOHC VTEC Flywheel $30
OEM Rear shocks from 95 integra LS good condition $40/both
Rear 99-00 SiR Stock rear Springs $20
Rear 99-00 SiR Stock rear Shock $20 (just have one)
OBD2B CRV engine wiring harness (might fit civic as well, not sure but looks like it would) $45
Injectors got lots just inquire I got OBD0,1,2
CRV Injectors $25
B16 Short Block with P72 pistons assembled (willing to part out anything from the short block) just inquire
MORE PARTS COMING SOON
Modified by R6 at 6:30 PM 5/7/2006
Modified by R6 at 12:40 AM 5/9/2006
All parts are OBO
SOME MORE PARTS
LS Flywheel $40
CRV Injectors $25
