FS ******Misc Parts***** updated regularily
Best way to get ahold of me is msn crxboy69@hotmail.com or email me
I have pics for all parts so if you want a pic just ask
PRICES DO NOT INCLUDE SHIPPING
All parts are OBO
P75 ecu $80
PreOBD-OBD1 Alternator $60
DC\EG mounts 3 main mounts $75
B series non VTEC dizzy $75
D16Z6 short block ... no crank pulley ... Parting out cause it burns a lil oil...
D16Y8 Block - basically everything minus crank disassembled (willing to part out oil pump, water pump, pistons, rods, crank pulley, etc...)
88-89 CRX bumper signal lights $20
D series starter $40
B series starter $50
CTR power steering pump $50
sohc vtec power steering pump w/ resevoir $40
Non vtec integra 94+ power steering pump w/ resevoir $50
94+ integra drivers side mount have both pieces $50
B16 oil pan $40
PM6 ECU 88-91 CRX/Civic Si OBD0 $30
SOHC VTEC water pump $30
Electric VSS (D or B series) $45
94+ integra rad fan $35
99-00 SiR Master Cylinder 15/16 and Prop Valve non ABS $70 MINT!!!
4-wire O2 sensor $30
OEM CRX shift **** $10
88-89 CRX taillights I have two complete sets mint $50/set
D16A6 Cam, Cam Gear, Cam Seal $30
D16A6 intake manifold gasket and exhaust manifold gasket some other random gaskets $10
MSD Blaster SS coil $20
Ignition coil from B series distributor (fits D as well) $40
B series Pressure Plate came from an B18B $30
LS Flywheel $40
SOHC VTEC Flywheel $30
OEM Rear shocks from 95 integra LS good condition $40/both
Rear 99-00 SiR Stock Springs $20
Rear 99-00 SiR Stock Shock $20 (just have one)
OBD2B CRV engine wiring harness (might fit civic as well, not sure but looks like it would) $45
Injectors I got OBD0 $30
CRV Injectors OBD2 $30
Modified by R6Boy69 at 10:19 PM 5/15/2006
Modified by R6Boy69 at 11:21 AM 5/24/2006
Modified by R6Boy69 at 10:24 PM 5/30/2006
Modified by R6Boy69 at 12:15 AM 6/1/2006
Modified by R6Boy69 at 11:19 AM 6/4/2006
Modified by R6Boy69 at 4:36 PM 6/12/2006
All parts are OBO
P75 ecu $80
B16 oil pan $40
LS Flywheel $40
