Del Sol Still Won't Start
Old May 6, 2006 | 09:51 AM
gilligan354's Avatar
Default Del Sol Still Won't Start
My del sol still will not start. I have checked EVERYTHING. ECU, MAP sensor, Distributor, main relay, spark plugs, timing belt, all the fuses, the plugs are dry, pretty much everything checks out Ok, it seems. The car does like it wants to start, but it will not fire up. When carb cleaner is sprayed in the intake it almost goes all the way. I'm getting fuel. Fuel pump is ok, fuel filter is ok, injectors are ok. I've just tried a little trick someone listed where you heat up the distributor. I am completely out of ideas. Please, please help!
Old May 6, 2006 | 10:22 AM
Stoich EG2's Avatar
Default Re: Del Sol Still Won't Start (gilligan354)
check all grounds. try switching the tps and map sensor. you might have them backwards
Old May 6, 2006 | 10:23 AM
Stoich EG2's Avatar
Default Re: Del Sol Still Won't Start (ADVAN EG2)
also check out the 15A ACG fuse under the dash
this all comes from my personal experience
Old May 6, 2006 | 11:16 AM
blueshark's Avatar
What is your fuel pressure? These guys need at least 25 psi to start cold. If your spark is STRONG and compession is good. (170-205 psi) and the MIL is not coming on the problem may be fuel related.
JesusGLS
Jan 13, 2013 04:59 AM
MA4MA
17
Apr 8, 2011 07:00 PM
Mike97LS
10
Nov 12, 2008 09:46 AM
t4tejas
Apr 30, 2008 02:27 PM
