no hoist to take out motor
Why dont you guys just drop it out from the bottom. Take out da axels and the crossmember lower the car on the jack then jack the car up from the rear tow hook loosen the mounts and wire harness jack the car up and look motor on the ground. Easy day
Just my 2 cents
Just my 2 cents
essentially you could do it, me and my dad can pick up my si block, but thats out of the car, it might be a bit more difficult with the engine in
i dont' think i could move the hoist around out in my dirtway it's all dirt and sand. wish i had a pave driveway anyone do a swap on dirt???
but if i use a hoist i won't be able to move it from one car to the other on the dirt . the hoist's wheel will jsut dig into the ground
your going to have troubles any route you take using a hoist on dirt, just take em out the bottom like everybody is telling me to, and use tarps to keep em off dirt.
then just pull the tarp with the motor on it to wherever you need it
I did my swap on a gravel driveway with a rented cherry picker. It's a pain but very possible. If you get a strong pole or something you can chain the engine to it and lift it out with a guy on each side of the car. I got my old d16 out by jacking it up as high as i could and climbing into the bay behind it and then pushing/lifting it out. I put an old carpet on the bumper to stop it from getting scratched.
Yes you can pick it up. I'm not a big guy and I can pick up a D motor with no tranny, with another guy I can pick up the whole thing. Pull the head and it should be easy, I was carrying my block around last week to clean it and stuff and I dropped it on my knee and foot, no prob it didn't even break anything, they are very light.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joeny12985 »</TD></TR><TR><TD CLASS="quote">i dont' think i could move the hoist around out in my dirtway it's all dirt and sand. wish i had a pave driveway anyone do a swap on dirt???</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">How-To: Install Motor By Yourself</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downest »</TD></TR><TR><TD CLASS="quote">Yes you can pick it up. I'm not a big guy and I can pick up a D motor with no tranny, with another guy I can pick up the whole thing. Pull the head and it should be easy, I was carrying my block around last week to clean it and stuff and I dropped it on my knee and foot, no prob it didn't even break anything, they are very light.</TD></TR></TABLE>
A longblock weighs 220 lbs fully loaded, the transmission weighs 60 lbs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joeny12985 »</TD></TR><TR><TD CLASS="quote">you guys think a buddy of mine and me can LIFT a d15 out of a car. no head or alt.? (drain fuild would prob help too. let me know if anyone did it?</TD></TR></TABLE>
yes... im 5-11 155 lbs and i can pick up a motor with no tranny... me and a friend can easily pick up a motor and tranny...
a b-series i wouldint recomend but a d-series shouldint be a problem
Looks like back problems in your future, I used to be able to lift a lot when I was young, and now I'm paying for it. I still work on the cars but man does it hurt!
ok, do NOT use a floor jack on dirt.
it can shift and you will be killed.
if you have to do it on dirt, get a 3x3 piece of solid metal. like an old car floorpan or something. jack the car up on that, to allow some sort of stability against the dirt.
i talk to my father today and his going to let me have his(i have to drive four hours to get it but it will be MINE MUAH MUAH HAHAHA
. i'm going to get it this weekend when i go to ct to see my mother and my gf's son.
if i was you i would just jack the motor out of the car. you can do that by putting the jack under the motor first then jack it up just until it has a little pressure on it. the i would loosen the mounts and axles and stuff and just jack it out threw the top
you could take it out the top with two guys (i've done it,), but it would be WAY easier on you to take it out the bottom if you have the space. use the tarp
me and 3 of my buddies lifted the d15 out of my car with the tranny on, wasnt that hard at all when it came down to it -- i expected it to be worst.
but i would recommend a cherry picker for when you reinstall it at the least.
