Will I have Cruise Control with an JDM H22 w/ euro R Manifold?
I'm about to do my JDM H22 swap and It already has a euro r manifold and a Nissan throttle body that 95mm in diameter (yes it's true). I was wondering if and how I can still run cruise control. I understand there are sacrifices for performance but I use it a lot and it would be sweet if I still could. I have a 93 accord ex coupe by the way. Let me know what you guys think.
You should be able to keep it. If I remember correctly, the cruise control cable acts directly on the gas pedal, not the throttle rotor.
Well, there are two vacuum hoses that go to the cruise control on the f22 and I haven't looked yet to see if there are two on the euro r mani. Here's a picture of the f22 mani with the vacuum lines circled
Credit for the pic goes to CP[mike] on CB7Tuner.com
I'll have to check for those two vacuum spots in my new motor
If you need to, you could drill and tap some holes to put fittings in. Or you could run T's off of existing lines on the Euro R manifold.
