rear mount ?
I dont remember what I used but I didn't have a problem getting on it but I also have 55,000 dollars of snapon tools, if you cant get it drop the subframe a little.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thirteen20CRXSi »</TD></TR><TR><TD CLASS="quote">how do i get to the back bolt on the rear mount i need to move it over to the 5 speed spot because i did the auto to 5 speed conversion,.. thanks</TD></TR></TABLE> You need to lower the rear crossmember, if you can't get it low enough that way you have to remove it from the chassis.
