jdm '93 integra xsi/rsi cable or hydro tranny?
I just bought a jdm b16a engine from a '93 integra xsi, this is a 2nd gen b16a obd1, but don't know if the clutch is for a hydro or cable tranny. I know the 89-91 jdm xsi/rsi have cable tranny's but does the 92-93 xsi/rsi also have cable tranny's or hydro?
Who can help?
Who can help?
Look at your firewall. Is there a second master cylinder for the clutch? If not, it is a cable transmission. It should be a cable transmission in that car.
don't have the car and transmission only the motor with clutch/flywheel.
Would like to put a hydro tranny on it, but don't know if it fits the clutch...
Missed the part about it just being the engine. I think that a hydro transmission will bolt right up. I'm not sure about the clutch. Just sit tight and someone will respond.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej_b16a »</TD></TR><TR><TD CLASS="quote">I just bought a jdm b16a engine from a '93 integra xsi, this is a 2nd gen b16a obd1, but don't know if the clutch is for a hydro or cable tranny. I know the 89-91 jdm xsi/rsi have cable tranny's but does the 92-93 xsi/rsi also have cable tranny's or hydro?
Who can help?
90-93 tegs have cable trannies, but the clutch from 92-01 are the same...the only one that has a difference is the 90-91 clutchs, they are different because the transmission has a smaller clutch spline
Who can help?
</TD></TR></TABLE>90-93 tegs have cable trannies, but the clutch from 92-01 are the same...the only one that has a difference is the 90-91 clutchs, they are different because the transmission has a smaller clutch spline
thanx for the replies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">
90-93 tegs have cable trannies, but the clutch from 92-01 are the same...the only one that has a difference is the 90-91 clutchs, they are different because the transmission has a smaller clutch spline</TD></TR></TABLE>
So do you think a hydro transmission will fit the clutch I have?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej_b16a »</TD></TR><TR><TD CLASS="quote">thanx for the replies
So do you think a hydro transmission will fit the clutch I have?</TD></TR></TABLE>
yes that clutch should work.
SnowSurfer
10
Jun 15, 2005 01:57 PM
swoosh
Mar 15, 2004 01:14 PM
