Security: How to wire up a fuel cut off and power lock by-pass?
Guys,
I was looking at this thread https://honda-tech.com/zerothread?id=159910and I am interested in the solution suggested, but I need more info on exactly what to do.... Can anyone help? Also, how about making a tutorial on how to wire up a fuel cut off. My interior is already ripped apart, so is it as easy as cutting the power wire, adding wire to both sides and adding a switch? Thanks!
I am looking in the book and I see there is a yel/green and yel/blk wire. yel/black in ground. Does it matter which one I use? It should work either way I believe.... Any correct me if I am wrong.......
get to the fuel pump, and unravle all the tape around the wires that directly connect to the pump. there is only one yellow wire, cut that. i have done this twice and works perfect.
ANy perticular switch that you like to use? DOes it need to be a certain amount of amps?
i dont think it has to be a certain number of amps. i just picked up two automotive switches at radio shack(the only one they had). i believe they were 25 amps. im not positive though.
I will check out the wiring deal... Now does anyone know anything more about using the sunroof switch and hooking it up the the Power Door locks??? Thanks!
I believe that the stock fuel pump fuse is rated at 15 amps, so the switch should be rated for at least that.
LaOXXKIDD
Oct 15, 2009 11:42 AM
SHG_Wacky
Feb 21, 2007 08:25 PM
BME1986
10
May 31, 2004 10:05 AM
