moonroof rattle...
Old May 5, 2006 | 11:13 PM
jdmnash's Avatar
Default moonroof rattle...
when it is open at all, it rattles towards the front. anyone familiar with the mechanism? have you had probs with this? Thanks...jart
Old May 6, 2006 | 07:48 AM
shiux's Avatar
mine rattles like crazy, i usually just turn down my stereo and its not as bad. no idea how to fix it though =P
Old May 6, 2006 | 09:42 AM
SlimBB4's Avatar
Default Re: (shiux)
just get a 5th gen sunroof conversion done and you never have to worry about that anymore....
_zAC
Old May 6, 2006 | 09:46 AM
helicopter201's Avatar
Default Re: (SlimBB4)
i concur i love mine so much. check the mounting bracket bolts see if they are screwed tight. also might put some rubber washers on them to reduce vibrations.
Old May 6, 2006 | 09:48 AM
limpmode's Avatar
eh my 5th moonroof chatters while moving on the track and makes a loud clap like sound when it closes.... I've greased it and taken it to the dealer and it does'nt help. No rattles at all tho.
Old May 6, 2006 | 11:44 AM
projectwidow's Avatar
Default Re: (limpmode)
I have the same problem when Im driving on bad roads. When I push up on it, it stops. Wonder what that could be.
Old May 6, 2006 | 12:00 PM
yOnKiNaToR's Avatar
Default Re: (projectwidow)
probably just old age of part. clearances of parts is getting bigger causing the parts to rattle. maybe spraying some thick grease in there will act as a damper.
satsilprelude
Aug 11, 2006 12:17 PM
wanderingpig
Jul 22, 2006 01:47 PM
Dongoesby
Nov 24, 2005 07:29 AM
BB6racer
May 24, 2005 04:15 PM
96 Accord Ex V6
Jul 30, 2001 07:20 PM
