changed timing belt, wont start!
Old May 5, 2006 | 10:09 PM
CaseBone's Avatar
Default changed timing belt, wont start!
So yesterday I changed my timing belt and put everything at TDC and put the belt on snug and did everything right the first time but when I got done, my car wouldnt start. It trys to turn over but it wont start. It is the timing? I double checked everything before I put the covers back on and it was all lined up perfectly!
Old May 6, 2006 | 02:54 PM
CaseBone's Avatar
Default Re: changed timing belt, wont start! (X92B18C1TegX)
help please!
Old May 6, 2006 | 05:13 PM
InfamousDC2FI's Avatar
did you put the spark plugs in? did you recconect the battery?? does it even turn over??
Old May 6, 2006 | 05:28 PM
Dogginator's Avatar
Daisy... Daisy...
Did you use the white mark or the red mark on the crank pully to find TDC? The white mark is the correct one.
Old May 6, 2006 | 06:24 PM
CaseBone's Avatar
Default Re: changed timing belt, wont start! (Dogginator)
I used the notch on the crank gear to find TDC, where is the white mark that im supposed to use to find TDC located, is it on the gear or pulley?
and yes everything is hooked up
Old May 6, 2006 | 07:24 PM
__oversea's Avatar
http://www.c-speedracing.com/h...t.php
Old May 6, 2006 | 08:20 PM
MyTEC4's Avatar
its on the pulley. dont use the knotch in the cover, thats no good.
Old May 7, 2006 | 01:55 PM
CaseBone's Avatar
Default Re: changed timing belt, wont start! (MyTEC4)
So I'm 100% positive I timed it right today and still wont start!
the spark from the plugs are kind of weak so I'm going to change those out tomorrow
could that be the problem?
Old May 7, 2006 | 05:24 PM
MyTEC4's Avatar
yeah that could be part of the problem. you always got to check the little ****. i changed my spark plugs one day went to start it and somehow my starter went out. weird crap man.
Old May 7, 2006 | 08:02 PM
CaseBone's Avatar
Well I really hope thats it and hope that doesnt happen to me!
Old May 7, 2006 | 08:16 PM
Ruben19's Avatar
check your firing order.
Old May 8, 2006 | 12:25 PM
CaseBone's Avatar
Default Re: (Ruben19)
How?
Old May 9, 2006 | 07:11 PM
CaseBone's Avatar
Default Re: (X92B18C1TegX)
So I replaced my cap, rotor, spark plugs, wires but didnt start still! I dont know what else to look for?
Any suggestions?
Old May 9, 2006 | 07:17 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X92B18C1TegX &raquo;</TD></TR><TR><TD CLASS="quote">So I replaced my cap, rotor, spark plugs, wires but didnt start still! I dont know what else to look for?
Any suggestions?</TD></TR></TABLE>
grounds?
Old May 9, 2006 | 07:34 PM
Wayne_Curr's Avatar
Default Re: (projectTeG)
Have you isolated the issue? Have you determined that you aren't getting spark for sure or are you just not getting fuel...if you lined up all the marks properly or even close to properly you'd be able to fire it right up, just wouldn't run right.
Old May 9, 2006 | 07:37 PM
SuzukaBlueAP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X92B18C1TegX &raquo;</TD></TR><TR><TD CLASS="quote">How?</TD></TR></TABLE>
You don't know how to check the firing order but you're 100% sure that you set the engine to TDC?
Have you made any progress with your issue? The first time I changed a timing belt I had the timing 180 degrees out. It would spit and sputter but never started.
Old May 9, 2006 | 09:11 PM
dc5_integra's Avatar
I sure hope that your timing is right because those are interference engines so if your turned it over with the timing out of wack you could bend a valve....
Old May 10, 2006 | 09:12 AM
projectTeG's Avatar
Default Re: changed timing belt, wont start! (dc5_integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc5_integra &raquo;</TD></TR><TR><TD CLASS="quote">I sure hope that your timing is right because those are interference engines so if your turned it over with the timing out of wack you could bend a valve.... </TD></TR></TABLE>
that would be a rare occurrence, if his cam timing was off.
Modified by projectTeG at 8:52 PM 5/10/2006
Old May 10, 2006 | 11:43 AM
out-of-whack ignition timing is not going to cause piston to valve contact.
Jdbdkid93
15
Jan 25, 2021 05:20 PM
ddn1313
Aug 4, 2018 02:46 PM
Macnotiss
10
Oct 18, 2017 05:44 PM
jonnybadboi9
Jul 16, 2009 11:40 AM
nighttrain33
Mar 23, 2008 01:38 PM
