d16z6 high comp. piston ? ?
i just wanted to know what is the highest compression ratio i can have on 91 pump gas in a d16z6 and also if i decide to go on the bottle what comp ratio is safe for that? thanks
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
If you have 94 octane and and want a simple hi comp sohc setup go with 89 integra (zc) pistons as for the squeeze......you will need a forged piston depending on how much nitrous you are looking to run
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS »</TD></TR><TR><TD CLASS="quote">If you have 94 octane and and want a simple hi comp sohc setup go with 89 integra (zc) pistons as for the squeeze......you will need a forged piston depending on how much nitrous you are looking to run</TD></TR></TABLE>
pm7 pistons
but careful with the juice
pm7 pistons
