BAD WHEEL BEARING
Ok my front RIGHT wheel bearing is bad and I need a new one. What is the correct part number for it in the link below there seems to be two different bearing part numbers witch is it?
http://www.barancoacuraparts.c...Irno=
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efvader »</TD></TR><TR><TD CLASS="quote">we have them in stock and i need to buy one for my teg
If you have it in stock, why do you need to buy it?
</TD></TR></TABLE>If you have it in stock, why do you need to buy it?
just a quick q, what are some symptoms that the bearing is going out or is dead? as i drive, i hearan odd noise coming from the fr driver side. and especially when you turn, it makes a loud continous noise til you get the car staright again.
If you jack that wheel up off the ground and grab the tire, you can feel play between the wheel and the hub. Also, when bearings go, the rim will get really hot, similar to when brakes drag.
Bad axles can also cause noises while turning, but usually of the clicking variety.
axles were both replaced last week. new tires, wheels rebalanced. brembos on the way with hawk pads. its not a clicking noise. its a loud dragging noise. [i cant figure out how to describe this noise]. it does it when you turn but not when going staright.
rino924
Aug 14, 2006 10:25 AM
