how do i check codes on a 91 accord ???
Old May 5, 2006 | 03:07 PM
davidcrx89's Avatar
Default how do i check codes on a 91 accord ???
Just like it says Thanks
Old May 5, 2006 | 04:24 PM
Ross 2.0's Avatar
In a Junkyard near you.
Engine light? S light... give us some insight here
Old May 5, 2006 | 05:29 PM
BLKFLSH's Avatar
Default Re: how do i check codes on a 91 accord ??? (davidcrx89)
Remove the little kick panel in front of the passenger door. You will see a two wire plug. Connect the two wires together with paper clip or wire. Turn the key to on, and count blinks of the Cel, D4 light, which ever one has a code stored. The long blinks are for the ten spot, short blinks are for the one spot. Example: three long blinks, followed by two short blinks would be code #32. There could be more than one code, so let it go through the codes a few times to make sure you have the right ones. Good luck
Azaria
Aug 17, 2018 11:59 PM
76 camaro car
Aug 1, 2015 12:11 PM
screammy
Aug 6, 2009 09:41 PM
FTW_Accord94
Nov 29, 2008 12:15 AM
JDM-EJ1
Apr 5, 2005 11:55 AM
