Spoon monblock fitment question
Old May 5, 2006 | 03:06 PM
Status Sean's Avatar
Default Spoon monblock fitment question
I purchased the Monoblock calipers, I understand that you need to run a 300mm rotor. But when searching for info most of the stuff in the archives was right around the time they were released.
Basically all I want to know is if these calipers will fit under 16'' wheel.
I understand I might need to use a spacer
thanks for the help
Old May 5, 2006 | 05:10 PM
Default Re: Spoon monblock fitment question (rw92civic)
bump
Old May 5, 2006 | 05:18 PM
Takumi Fujiwara's Avatar
They fit under 15" wheels with the correct offset.
Old May 5, 2006 | 05:21 PM
mugenracer's Avatar
I thought that they need to be used with 282mm rotors....
Old May 5, 2006 | 05:35 PM
Reid's Avatar
Global Moderator
Default Re: Spoon monblock fitment question (Takumi Fujiwara)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takumi Fujiwara &raquo;</TD></TR><TR><TD CLASS="quote">They fit under 15" wheels with the correct offset.</TD></TR></TABLE>
Are you sure? Do you have a pic by any chance to support your claim?
I was under the assumption that you needed to use a 16" wheel at minimum with the monoblock calipers.
Old May 5, 2006 | 05:56 PM
Default Re: Spoon monblock fitment question (Reid)
I was under the assumption that you needed a 300mm rotor.
and thinking back on all the cars that i've seen using them, they were using a 17'' wheel I just want to make sure they will work with my 16x7 before I finish ordering all of my other brake components
Old May 5, 2006 | 05:59 PM
I'm pretty sure there is noway possible these brakes would ever fit under a 15'' wheel.
Old May 5, 2006 | 06:19 PM
jdm_DC2R's Avatar
Here are my spoons, under stock 15" itr rims, no spacers or anything, straight bolt on.
Old May 5, 2006 | 06:21 PM
Reid's Avatar
Global Moderator
Default Re: Spoon monblock fitment question (jdm_DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_DC2R &raquo;</TD></TR><TR><TD CLASS="quote">Here are my spoons, under stock 15" itr rims, no spacers or anything, straight bolt on.</TD></TR></TABLE>
Those are the twinblock calipers though. We're discussing the monoblock calipers in this thread.
Old May 5, 2006 | 06:31 PM
if moofx could just come in here it will solve all the problems regarding what rotor to use.
the question about a monoblock fitting under a 16 is still unanswered
Old May 5, 2006 | 06:34 PM
jdm_DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">
Those are the twinblock calipers though. We're discussing the monoblock calipers in this thread.</TD></TR></TABLE>
sorry my bad, i thought they would be the same dimensions...guess not.
Old May 5, 2006 | 06:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_DC2R &raquo;</TD></TR><TR><TD CLASS="quote">sorry my bad, i thought they would be the same dimensions...guess not.</TD></TR></TABLE>
I don't know that shiiet, keepin' it REAL!
Old May 5, 2006 | 07:04 PM
tommymoose's Avatar
I don't mean to threadjack, but I've never seen any information comparing the monoblock and twin-block but I've always been curious... does anyone have any links?
Old May 5, 2006 | 09:14 PM
Kavehman's Avatar
I think moofx tried them out, I believe he said the difference was negligible
Old May 5, 2006 | 09:22 PM
Default Re: (Kavehman)
yeah I already have them the diffrence in price "FOR ME" was only 100 dollars so why not.
but when I purchased them I was under the impression that they would fit under a 16'' wheel.
but now I am unsure and i'm also unsure of what front rotor I am supposed to order.
I know you need a 300mm by 26mm but im not sure what app. uses that
Old May 5, 2006 | 09:49 PM
RagingAngel's Avatar
Default Re: (rw92civic)
The rotor you could probably get to fit is from a TSX.
16inch wheels will fit - I believe if it's an SW388, it has to be a +35mm 16X7.
Count on running a good amount of negative camber to clear your fenders or wide fenders basically.
Need anymore help? http://www.aj-racing.com is probably the place to figure it out for you.
Old May 5, 2006 | 10:06 PM
Default Re: (RagingAngel)
Yeah I bought the calipers at aj-racing and they have not been able to help me out at all.
All I want to know is what app. I order the rotors for.
Old May 6, 2006 | 03:55 AM
ITR1227's Avatar
First, you need to know if you got the kit specifically for your car.
You haven’t mentioned if you have a Type R or a civic with 5 lug, but I’m guessing that is what you have. The following bold info is straight off of the Spoon page.
Monocoque Caliper Forward (Left)
INTEGRA TYPE-R [DC2, DB8(98Spec)*]
45019-MBF-G00
Monocoque Caliper Forward (Right)
45018-MBF-G00
(The same part numbers for EK9)
* You must use Brake Rotor part # 45251-5H11416
Brake Rotor (F)
INTEGRA TYPE-R[DC2,DB8(98Spec)], CIVIC TYPE-R[EK9]
For monocoque caliper installation
Outside diameter:300mm
Thickness:26mm
If your part numbers have an “MBR” instead of “MBF” then they are for S2000/DC5/EP3 and won’t have the correct mount adapters.
As for what other stock rotor you can use, I don’t know.
My wife is Japanese and searching right now, but she doesn’t know anything about cars, so she might not find what you need.
Old May 6, 2006 | 05:20 AM
kepani's Avatar
not sure if i'm seeing this right, but if your lug nuts have a tapered face, you might want to use the acorn style lug nuts. the stock itr wheels use only acorn style lug nuts!
kepani
Modified by kepani at 12:31 PM 5/6/2006
Old May 6, 2006 | 10:01 AM
Default Re: (ITR1227)
Nope I purchased the brakes for a ITR DC2
yeah I guess after reseraching the spoon rotors I dont want to use them so if I could find out what else i could use I would be in a good place.
Old May 6, 2006 | 10:41 AM
clayton bigsby's Avatar
from what i have heard the one person that has the monoblock on a dc2R is that he used nsx front rotors and pads with 17X7.5 advan RG's
Old May 6, 2006 | 11:49 AM
Erik95LS's Avatar
Default Re: (clayton bigsby)
They fit under the 16 spoon wheels on the s2k so I would imagine they do fit under certain 16 wheels. As to what rotors to use I have no idea.
Didn't mikehonda have them on his for awhile with the active gate rotors?
Old May 6, 2006 | 02:01 PM
Default Re: (Erik95LS)
BUMP
Old May 7, 2006 | 01:23 AM
bump
Old May 7, 2006 | 07:46 AM
ITR1227's Avatar
From what I can tell these were made to be direct replacements for s2000's. Kinda like twin-blocks are for DC2R's. So I would get an S2000 front rotor and put it on and check it out.
PS. The wife didn't come up with anything helpful. Sorry.
