2nd gear grinds but other gear is fine
Old May 5, 2006 | 02:56 PM
Pnoyej6's Avatar
* B A N N E D *
Default 2nd gear grinds but other gear is fine
i have 90 crx si. 2nd gear grinds but other gears are fine. Is it time to replace clutch?
Old May 5, 2006 | 02:59 PM
94_DC4's Avatar
Default Re: 2nd gear grinds but other gear is fine (pnoytegn707)
Your second gear synchro is bad!
Old May 5, 2006 | 03:00 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: 2nd gear grinds but other gear is fine (oemjdmdc)
so its not the clutch. do ineed to get synchro are they cheap??
Old May 5, 2006 | 03:01 PM
Pnoyej6's Avatar
* B A N N E D *
is it bad if i keep driving like this with the gear grinding. This is my beater car and i will eventually swap the motor to b16 later on.
Old May 5, 2006 | 03:06 PM
Pnoyej6's Avatar
* B A N N E D *
could it be tranny fluid is old
Old May 5, 2006 | 03:15 PM
Pnoyej6's Avatar
* B A N N E D *
Also i have cel. My cat is making noise like clatter noise. Could this be culprit. Car pass smog 2 months ago.
Old May 5, 2006 | 03:20 PM
cal_gecko's Avatar
My 86 CRX Si does the SAME thing.. it's just a little bit of a grind when I shift into 2nd.. nothing really bad, but it's enough that I notice it.
Old May 5, 2006 | 04:22 PM
doublethink's Avatar
try a 50/50 mix of sychromesh and honda MTF for a while....
might eliviate some of it until you swap.
Old May 5, 2006 | 05:39 PM
ed9crxsi's Avatar
Default Re: 2nd gear grinds but other gear is fine (doublethink)
The 2nd and 3rd gear synchros will go bad in CRX's alot of the time. I know alot of people always have trouble with 3rd synchros getting messed up more than 2nd though.
Old May 5, 2006 | 06:22 PM
ludesrv's Avatar
D series = Bad 2nd gears when beaten on.
Each tranny has there own.
Old May 5, 2006 | 08:43 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: (ludesrv)
Im getting my rex fixed by a friend dents and dings and then primered. Ill try the tranny mix with synchromesh
Old May 5, 2006 | 08:46 PM
ghost_ryder35's Avatar
Default Re: (pnoytegn707)
gm syncromesh works great. sychro is gone, its not bad to keep driving it its just going to get worse if you keep beating on it in that gear. try draining your tranny fluid and changing if its old it might not be lubricating well enough. what is your CEL light on for. should fix that you know!
Old May 5, 2006 | 08:58 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: (ghost_ryder35)
cel is on because my cat is making a clunk noise so i believe thats why. Gm syncromesh works great ?? How do i change tranny fluid on crx. Im more familiar with tegs not rex since im new to rex. I chose the crx si for project car because it is the best candidate for swap. No need to swap axles/hubs
Old May 5, 2006 | 09:23 PM
Pee Wee's Avatar
time to shift 1-3-4-5
Old May 5, 2006 | 09:29 PM
inh's Avatar
inh
no no. time to double clutch. sheesh
HondaRcB
Nov 24, 2006 11:41 AM
WILD_WILL
Honda Civic (2006 - 2015)
Oct 3, 2006 01:15 PM
vietnogi
Feb 2, 2006 11:36 AM
b00stn
Oct 25, 2002 02:22 PM
onyx00
Jul 26, 2002 06:57 PM
