$40 camber kits still available? The (up to) +1.5 ones?
I am looking for a generic camber kit that goes above the upper a-arms, only not the one with the sliding adjuster (0-3 degrees) but the one with 2 different bolt holes you can use. These seem more 'sturdy,' and also I noticed b18c5-eh2 mentioned that the 3 deg. ones are no good as they hit the car if adjusted all the way out. Does anyone know where to buy these anymore? I only see the ones with the sliding adjuster on ebay and what not.
My car is on neuspeed race springs (~2.5 in. drop) and I feel like +1.5 camber should put me right around where I want to be (for the front). This is a street car and the way it is now it has too much negative camber. Regardless of the popular belief around here that 'toe is what causes tire wear, don't worry about camber,' the tires should not spin in 5th gear in the rain on the freeway because only the inside edge of the tire is on the ground. It's not that safe.
So, anyone know where to get these anymore? Thanks in advance,
Art
Art
BlissSkr
Sep 23, 2004 08:34 AM
