valve cover gasket
Old May 5, 2006 | 01:19 PM
frank2660's Avatar
Default valve cover gasket
new member here going to replace the valve cover gaskets on 86 2.0 anything i should know or to look for thanks
Old May 5, 2006 | 06:29 PM
BLKFLSH's Avatar
Default Re: valve cover gasket (frank2660)
Be careful not to tighten the cap nuts too tight. They torque to only 7 ftlbs. The little studs snap easily = more problems. Why are you changing the gasket? Oil in the spark plug tubes?
Old May 5, 2006 | 06:32 PM
Ross 2.0's Avatar
In a Junkyard near you.
an 86 doesn't have spark plug tubes
That's one of the easiest ones to do
Is this a carb model or fuel injected?
Old May 6, 2006 | 03:34 AM
frank2660's Avatar
Default Re: (MooGoCow3)
it is a carb model and i can see oil leakin just got the car and want to stop the leak and look under for a tapping noise i am sure i will have ? latter thanks
Old May 6, 2006 | 06:54 PM
Dressed Accordingly's Avatar
YES! i have oil in three of my tubes all the way up to where i can just see the silver tip but been driving like that 4 years doesnt seem to run funny i think i gonna change them on the 15th so good thing i seen this post that must be the problem! oh ya 94 accord F22B2 SOHC NON VTEC auto 167K
Jesse M
Honda Civic (2001 - 2005)
Sep 13, 2018 01:42 PM
combustion
15
Apr 11, 2005 02:53 PM
BrokeLude
Aug 19, 2004 11:42 AM
4genaccordfreak
Jan 4, 2004 01:07 PM
One2chi
Jan 31, 2003 05:16 AM
