I hate these stupid Honda ricer idiots...
YOU CANT EVEN PUT AN EMBLEM ON WITHOUT ******* SOMETHING UP CAN YOU?
The aftermath of removing my piece of **** $3 red H emblem from the trunklid. Instead of cutting the $3 piece to make it fit, LETS ******* DRILL A HOLE IN THE BODY. HUHUHUHUHUHUH
H Emblem...
H Emblem...
Hahaha...when my black emblem fell off I got a cheap ebay black one to replace it and I broke the tabs off..how retarded were the past owners?
My best suggestion is to either fill it and get it painted (rrrr)
or just get an OEM one and stick it over. I know you wanted it clean but badly drilled holes arent clean
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRIUS »</TD></TR><TR><TD CLASS="quote">The stock emblems use those holes. Buy an OEM emblem, problem solved.</TD></TR></TABLE>
those holes seem bigger than the OEM emblem holes.
I already have them on the way, problem is though, these holes are probably going to be too big for that ****, PLUS, rust is starting on the insides of them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_lude »</TD></TR><TR><TD CLASS="quote">
those holes seem bigger than the OEM emblem holes.</TD></TR></TABLE>
Silicone Caulk+OEM emblem FTW
Beats having to do body work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KooK »</TD></TR><TR><TD CLASS="quote">
Use touch up paint on the edges after you clean them up to prevent the rust and then follow the above previous post.
</TD></TR></TABLE>Use touch up paint on the edges after you clean them up to prevent the rust and then follow the above previous post.
J.nguyen
Mar 18, 2007 10:51 PM
