ZC question From OBD1 to OBD0
Old May 5, 2006 | 07:46 AM
Angry's Avatar
Default ZC question From OBD1 to OBD0
At the possibility of actualy getting a NOn-vtec OBD1 SOHC ZC for cheaper than a OBD0 ZC. Im under the imprssion that I can swap my Stock Si harness onto the OBD1 ZC with the exception of the Dizzy, Could I then just grap a rywire or hasport OBD0 to OBD1 dizzy adapter harness? And then still use my stock harness until I make (if ever) the full swap to OBD1?
This would also allow me to get a slightly newer motor.
Thanks...Laterz...
Old May 5, 2006 | 08:48 AM
jlicrx's Avatar
Default Re: ZC question From OBD1 to OBD0 (Angry)
OBD1 distributor will not work with OBD0 ECU - use your Si harness, but you will need to use OBD0 distributor
better check out what the engine is - all of the OBD1 SOHC non-VTEC ZCs that we have seen are the dual carb model (may be why it is cheaper)
Old May 5, 2006 | 08:58 AM
Angry's Avatar
Ahh..I see...I might just go over to OBd1 comepletely and then swap in a Z6 or something or ZC v-tech...Hmm..More thinking and research...
D7_62
Classic Hondas
Aug 6, 2012 07:36 AM
hudson13
Dec 10, 2010 04:54 AM
crxzcracer
Mar 2, 2005 03:39 PM
Jon Black
Mar 12, 2003 12:36 PM
