Time to lower car... camber kit and other suggestions needed
Old May 5, 2006 | 06:51 AM
RacerTim's Avatar
Default Time to lower car... camber kit and other suggestions needed
I ahve an 2001 2dr 4cyl. IT has almost 100,000 miles on it. I just got a set of 18s for it, and it now needs dropped because they look way too small. I think I'm going to go with the eibach sportlines (because I still drive it everyday) and was thinking about the KYB GR2 shocks, probably need done at 100k anyways. I am assuming I need a camber kit for it too. Just go with the adjustable ball joints up front and the bolt kit in the back? I think I'm going to be picking up everything from Summit Racing. (discount and nearby, plus I'm working with limited time here) Summit carries the Ingalls camber kits and they are good from what I hear. Just let me know if there is anything else I need. I Want to pick this stuff up in the next couple days.
Thanks!
Old May 6, 2006 | 01:05 AM
H2290's Avatar
Default Re: Time to lower car... camber kit and other suggestions needed (RacerTim)
I believe the GR2 shocks are meant as a stock replacement. You would really be served better by something like the KYB AGX which are adjustable and made for lowered vehicles.
exratedaccord93
Sep 8, 2006 06:32 AM
Jax4gencivic
Jun 24, 2005 08:48 AM
blackriceman
Apr 9, 2004 03:42 PM
yellowbuffalo
Dec 24, 2001 08:20 AM
