Dirty Housing
Old May 5, 2006 | 06:11 AM
tsouyporta's Avatar
Default Dirty Housing
on my 2000 teg, the insides of my housing on my headlights are dirty. How do i open the housing to clean it, i don't want to break the housing (which is stock). Someone told me about cooking the housing?...please help
Old May 5, 2006 | 12:45 PM
.brian.'s Avatar
Default Re: Dirty Housing (tsouyporta)
yes, you can put them in the oven to heat them up and take them apart, but i am not sure, i have never done it.
are you sure it is not just the outside tha has the infamous "haze" on it? try polishing with neverdull, then put a coat of wax on and wipe off. that should help if the haze is on the outside of the lights.
edit: here is a link
http://www.team-integra.net/se...D=662
Old May 5, 2006 | 12:48 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: Dirty Housing (.brian.)
300-350 in the oven for about 7-10 minutes.
Just make sure once it gets around 7minutes you check up on it,
and have enough room so you're not touching anything inside the oven.
If it just has a haze like brian said, use either 1000, or 2000grit paper, and then buff it out with polishing compound.
kenzo42
Apr 5, 2007 04:08 AM
hondaj05
Sep 3, 2006 06:46 PM
I Like Hondas
Jul 5, 2006 11:16 AM
rota power
Jun 17, 2006 06:02 PM
GetupHeights
May 24, 2006 08:08 PM
