HELP! jdm dohc F22b into 94 Accord LX running ROUGH!
Old May 4, 2006 | 11:10 PM
Hung_Lo's Avatar
Default HELP! jdm dohc F22b into 94 Accord LX running ROUGH!
Hey,
I've just installed a jdm dohc f22b into my 94 accord lx.
When I start the car it runs ROUGH, I look at the plugs and it is running VERY rich.
When I check the codes, it shows a TPS code. When I put the Accord ecu back on, it shows a MAP sensor code.
I've changed the injectors, and still the same problem.
I am using the Accord tb with the built in MAP sensor.
Please help, I've had this thing sitting here for months.
Thanks.
Old May 5, 2006 | 07:33 AM
i_kick_turtles's Avatar
Default Re: HELP! jdm dohc F22b into 94 Accord LX running ROUGH! (Hung_Lo)
Which ECU are you using? The Accord one won't work.
Old May 5, 2006 | 07:14 PM
Hung_Lo's Avatar
Default Re: HELP! jdm dohc F22b into 94 Accord LX running ROUGH! (I R Tylor)
I am using an H23a and the stock ecu
Old May 5, 2006 | 08:42 PM
The h23 needs more fuel because it has higher compression than the f22b. This is why the p14 is making you run rich. You could chip a p06, or buy a p39.
Old May 5, 2006 | 11:49 PM
d112crzy's Avatar
h23 also has a knock sensor, your f22b doesnt. its prolly throwing a code for that.
Old May 6, 2006 | 01:05 AM
raceACCORDingly's Avatar
p39 ecu
76 camaro car
Nov 21, 2015 09:46 AM
xide_12
Mar 29, 2011 10:56 AM
xwade01
Mar 6, 2005 02:45 PM
BLACK_DEL_SOL
Dec 15, 2004 03:19 PM
jcusumano
Feb 5, 2003 10:43 AM
