not sure where this goes but "floor flooded due to thunderstorm las night"
Old May 4, 2006 | 10:07 PM
A-busive's Avatar
Default not sure where this goes but "floor flooded due to thunderstorm las night"
Does neone know how does floor gets covered in water in the whole car if the console and seats etc isnt wet(n im parked on a straight street dats hardly ever floods)...I woke up dis morning getting ready for work and bout to hop in my whole floors wet, n my ecu was laying on the ground w/the cover over it , it didnt so much get wet only only on the bottom, but i opened it up n its moisture in side i guess from the wires, but their ok and i cant start my car, idk if its because of the flooor sooo wet or what? idk please help
Old May 4, 2006 | 10:11 PM
96dxpower's Avatar
Default Re: not sure where this goes but "floor flooded due to thunderstorm las night" (A-busive)
try letting it dry out. like a cell phone whe nyou drop that in water it wont work for a while til it dries out
Old May 4, 2006 | 10:38 PM
A-busive's Avatar
The top square has goo under neath the connetor just a lil and the 2nd has a lil goo also..sorry couldnt get necloser than that
well i went to work and look at the ecu and these 2 parts of inside have a lil goo, the rest of the ecu i fine, but i havent tried to blow fry it yet, and havent tried to install it again yet either*The top square has goo under neath the connetor just a lil and the 2nd has a lil goo also..sorry couldnt get necloser that that*
Old May 5, 2006 | 09:11 AM
A-busive's Avatar
bump does neone know how i can go about with the water onthe floor
Old May 5, 2006 | 09:13 AM
KimChiKid's Avatar
Time to strip the interior that is going to stink?
Old May 5, 2006 | 09:20 AM
Ls_V_TurboSi's Avatar
Default Re: not sure where this goes but "floor flooded due to thunderstorm las night" (KimChiKid)
shop vac the car or get as much water up as possibly then leave the car running with the heater on.
Old May 5, 2006 | 09:40 AM
A-busive's Avatar
Default Re: not sure where this goes but "floor flooded due to thunderstorm las night" (Ls_V_TurboSi)
well just a few minutes ago i went outside to plug the ecu up and it work so chea i'm happy, now i can drive my car up the drivway so i can shopvak
Old May 5, 2006 | 09:57 AM
existanzcivicb20's Avatar
glade to hear its ok
but I would take the carpet out wash it then shopvak it and spray it down with carpet cleaner that smells good hope it help it worked for me
Old May 5, 2006 | 10:14 AM
KimChiKid's Avatar
Old May 5, 2006 | 10:35 AM
dpkelly's Avatar
I had a leak in my car in several places allowing water in. Check out this link that I started in the sister forum honda-acura.net.
http://www.honda-acura.net/for...water
I knew water came from those 2 locations since I drove it in the rain with a paper towel wedged under the dash between the left wall and the fire wall and it got wet. I still have water getting in so I'm planning to remove the dash and try patching it up from the inside. The hole in the honda bulletin was hard to reach and can only be seen by removing the left front bumper. It's a royal PITA since it takes along time to find the source and patch up. Goodluck!
Old May 5, 2006 | 12:42 PM
A-busive's Avatar
Default Re: not sure where this goes but "floor flooded due to thunderstorm las night" (dpkelly)
yeah thanx for all that, but i came to the conclusion that when i took off my side molding (95 coupe)when i got my car 2 years ago i didnt like it b/c my car was white n the molding was black. So for awhile i was debating if i wanted my doors shaved so i left the molding off n threw them away b/c i bent most of them in the process. N through on the year or so of thinking of getting it shaved i decided not to and begin to find some moldings to put back on but paint them white, but havent yet came across ne in good condition, which leads me to now that i still dont have them which cause alot of water from the thunderstorm to get into the holes along the sides of my car...i thought of that because when i'm at a car wash i most of the times spray at the door and when i'm done theirs water on the doorsill
Old May 5, 2006 | 01:08 PM
MonkeyPuzzle's Avatar
i had a car float away in a flood.
We simply pulled the seats carpet and ecu, opened up the ecu and let it dry.
We checked all the fuses and replaced those that blew.
Then let everything dry before we tried to start it
The carpet took ages so for nearly a month we drove around with no carpet, but thats half the people on H-T anyway
Old May 5, 2006 | 01:38 PM
96dxpower's Avatar
Default Re: not sure where this goes but "floor flooded due to thunderstorm las night" (MonkeyPuzzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonkeyPuzzle &raquo;</TD></TR><TR><TD CLASS="quote">
The carpet took ages so for nearly a month we drove around with no carpet</TD></TR></TABLE>
sunny so cal dried up my carpet in 3 days
Old May 5, 2006 | 01:45 PM
JdmLub's Avatar
Default Re: not sure where this goes but "floor flooded due to thunderstorm las night" (96dxpower)
when my window seals leeked, my interior was f*ed uped, just left a lil warmer in my car for about 3 days, dryed it out, then i just cleaned my carpets.. got the good smelling stuff at the gas station
Old May 5, 2006 | 01:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96dxpower &raquo;</TD></TR><TR><TD CLASS="quote">
sunny so cal dried up my carpet in 3 days </TD></TR></TABLE>
i lived in the extremely humid tropics of Queensland australia.
It did have one bonus though, I was designated driver and one of my intoxicated friends threw up all over my car. was nice and easy for HIM to clean up
TwoKSiR
Jun 15, 2008 09:41 AM
EH3Civic
Nov 16, 2007 06:36 AM
b16edeg
Jun 30, 2007 08:26 PM
BLUE EH3
Oct 13, 2005 05:42 PM
hahahahhah
18
Feb 13, 2003 10:59 PM
