Mazda RX-7 Convertible Wheels on a ITR anyone?
Old May 4, 2006 | 07:50 PM
ProjektR's Avatar
Default Mazda RX-7 Convertible Wheels on a ITR anyone?
Anyone ever tried to put a set on a ITR? I just got a set cheap online. I just went out to check out how they fit and well there's a slight gap between the hub and the center of the rotor. I put them on and tightened the lugs at much as I could hand tight. They seem to clear the rotor and caliper, just not sure why I can't move the wheel in deeper. Will that slight gap be a big problem? Anyway around it? Any help or advice would be welcomed. Thanks!
Old May 5, 2006 | 10:37 AM
Dave-ROR's Avatar
Default Re: Mazda RX-7 Convertible Wheels on a ITR anyone? (ProjektR)
They should fit as long as they clear the hub center (diameter). They may not be flat on the back so it may have been flat even if it didn't look like it.
They are light though so I'd check to see if it was really flush or not cause they would be nice wheels to use
Old May 7, 2006 | 07:57 PM
ProjektR's Avatar
Default Re: Mazda RX-7 Convertible Wheels on a ITR anyone? (Dave-ROR)
I found out the only thing holding them from lining up flat is the center of the hub where the lil thing protrudes for the axles... I can slide a business-card or 3 behind it. Maybe if I get a thin spacer to put space between or if I goto a machine shop and get them to enlarge the center portion of the wheel a bit to fit over I think it'd work. A lot of work I know but these wheels hella light and I got them for hella cheap... I could even go ghetto and dremel the sucka a bit...
mr_munro
Sep 26, 2012 10:04 PM
Type_RS_59
Sep 21, 2007 09:16 PM
ProjektR
May 9, 2006 10:31 PM
markpaco
May 19, 2005 08:42 AM
