2.5" header flange to stock cat with a Dodge Neon donut gasket ?
Old May 4, 2006 | 07:38 PM
MOVE OVER's Avatar
Default 2.5" header flange to stock cat with a Dodge Neon donut gasket ?
One of my friends told me that he used a Dodge Neon donut gasket to connect his JDM header to his stock USDM 2.25" flange cat....
I wanted to know if anyone else has done this or heard of it, and what all is entailed in connecting the pieces. If you have pics, that would be great...
I am trying to connect a Kamikaze header (2.5" flange) to the stock cat with as little work as possible, because the entire exhaust will be getting replaced later on.
Thanks,
Kevin
Old Aug 10, 2006 | 10:46 AM
CW-ITR's Avatar
Default Re: 2.5" header flange to stock cat with a Dodge Neon donut gasket ? (ITR 1102)
Facing the same situation and I already tried the "search". I am trying to connect a Hytech header (2.5" flange) to the stock cat. If you guys and gals know what will work, please chim in and help me out. Thanks.
Modified by CW-ITR at 11:59 AM 8/10/2006
Old Aug 10, 2006 | 11:02 AM
Eva01's Avatar
Have a muffler shop weld on a 2.5 flange on the cat...although going from a 2.5" collector to a 2" cat and exhaust is creating a significant bottleneck.
Old Aug 10, 2006 | 11:08 AM
CW-ITR's Avatar
Default Re: (Eva01)
Will an OEM JDM cat prove to be better?
Old Aug 10, 2006 | 11:13 AM
CW-ITR's Avatar
If the JDM cat is better then...how do I bolt the outlet of the cat to the B-pipe?
Old Aug 10, 2006 | 11:56 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (CW-ITR)
You can get a donut gasket from Honda also. The s2000 uses a 2.5 gasket and so does some CRV's
Old Aug 10, 2006 | 03:43 PM
QuickDxEk's Avatar
I went to my local auto parts store and in the back they have a large selection of universal parts. I have found many different sizes of donut and exhaust gaskets!!
schumi
Jul 23, 2005 09:14 AM
98itr0448
Aug 25, 2004 12:37 PM
Stock R
Jun 19, 2003 07:30 PM
itr0045
Feb 6, 2002 05:59 AM
