valve adjustment on b16a2 question
Old May 4, 2006 | 06:05 PM
naTRON's Avatar
Default valve adjustment on b16a2 question
okay, so i'm going to adjust the valve lash on my b16a2.... 1 of my boys said that i need extra long angled feeler gauges, my other boy said the regular ones i have (short & straight) will work.... who's right?
Old May 4, 2006 | 06:39 PM
EG2Driver's Avatar
Default Re: valve adjustment on b16a2 question (naTRON)
am not sure buts its better if the valves are on the loose side then tighty side. Bumb for you
Old May 4, 2006 | 06:44 PM
SkoundrelUSA's Avatar
cute little bastard
As long as they're about an average sized finger length (3-4inches) it should be long enough
Old May 4, 2006 | 07:20 PM
egsleepercivic's Avatar
either should work, stated above, you want them at least 3-4 inchesw long, straght or angled
Old May 5, 2006 | 02:41 AM
naTRON's Avatar
Default Re: valve adjustment on b16a2 question (SkoundrelUSA)
thanks guys.... and why do i want them on the loose side.... i always thought it would be better to have them on the tighter side of the spec????
Old May 5, 2006 | 05:43 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
i use long angled, they are much easier to handle/use. and adjust them to spec. too tight and you will burn a valve, and too loose and you will not be using all your cam's profile.
cornhusker
Sep 20, 2003 03:37 PM
nY's FiNeSt
Jul 7, 2003 09:07 AM
95GS-R
Nov 9, 2002 07:25 PM
