different in sx and std
Old May 4, 2006 | 05:19 PM
JJ's civic's Avatar
Default different in sx and std
jsut bought an std for parts.. then my project. i need to use the front end the suspenssion parts. do they fit or are the brackets differnt?? help please before i get in too deep
Old May 4, 2006 | 05:27 PM
CRX Toad's Avatar
Default Re: different in sx and std (joeny12985)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joeny12985 &raquo;</TD></TR><TR><TD CLASS="quote">jsut bought an std for parts.. then my project. i need to use the front end the suspenssion parts. do they fit or are the brackets differnt?? help please before i get in too deep</TD></TR></TABLE>
I don't know what you are asking. This is very vauge.
Old May 4, 2006 | 05:34 PM
fbw2003's Avatar
im guessing that you meant dx not sx but for the brackets go they should be all the same the difference is the engine and tranny dx has a d15b1 and a five speed and a std has a d15b2 and a four speed. the only thing i would worry about is the year. the different years have different things.
Old May 4, 2006 | 05:43 PM
Tyson's Avatar
Default Re: different in sx and std (fbw2003)
everything is pretty much the same on the STD and DX except i think the STD has a smaller hub (and axles), and does not have the front swaybar.
Old May 4, 2006 | 06:10 PM
JJ's civic's Avatar
Default Re: different in sx and std (Tyson)
what's the differnts in motors? d15b1 and d15b2 what's the differnts?
Old May 4, 2006 | 09:25 PM
Import Al's Avatar
D15B1 = DPFI 70 hp '88-'91 Civic STD engine.
D15B2 = DPFI 92 hp '88-'91 Civic LX/DX & base CRX engine
They 'basically' share the same block as the D15B7 (92-95 DX/LX) and head casting with the D16A6 88-91 Si engines.
Old May 5, 2006 | 05:16 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joeny12985 &raquo;</TD></TR><TR><TD CLASS="quote">what's the differnts in motors? d15b1 and d15b2 what's the differnts?</TD></TR></TABLE>
The only differences between the DX and STD motor are the cam, ECU, and exhaust manifold setup. Simply upgrading these parts will effectively change your STD motor into a DX motor, which will increase HP from 70HP to 92HP. Although 92HP is not much, it DOES represent a 30% increase. And it feels like ALOT compared to 70HP, especially considering the car is light. Furthermore, it can all be done for less than $100, using junkyard parts.
Old May 5, 2006 | 09:16 AM
JJ's civic's Avatar
Default Re: different in sx and std (StorminMatt)
cnai just swap heads from my dx motor to the std's motor?
Old May 5, 2006 | 09:23 AM
Ass$nyper's Avatar
Pirate General...YARRRR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joeny12985 &raquo;</TD></TR><TR><TD CLASS="quote">cnai just swap heads from my dx motor to the std's motor?
yes but other then the cam it's the same head.
STREETFIGHTER50
Jul 6, 2010 05:00 PM
jpanjie
Honda Civic (2001 - 2005)
Jan 21, 2008 01:12 PM
boostedSI90hatch
Mar 29, 2007 04:00 AM
TheCollectiveFoundation
Feb 23, 2006 06:43 AM
97LXecutioner
Jan 3, 2004 12:29 PM
