Suspension & Brakes Theory, alignment, spring rates....
22mm bushing with 21mm bar
Old May 4, 2006 | 05:06 PM
broketuner-Sol_Si's Avatar
Default 22mm bushing with 21mm bar
I have a blox 21mm rear sway bar that will soon be installed on my hatch. The bushing that come with it are a cheap *** rubber and very small. I'd like to get the ES aftermarket bushing kit but the closest I can find is 22mm. Can I get the ES kit and use it with the bar and everything be ok I mean it is only a 1mm difference, or should I put something on the bar to make the bushing section 22mm? any suggestions are greatly appreciated.
Old May 4, 2006 | 09:09 PM
Voyage34's Avatar
Default Re: 22mm bushing with 21mm bar (broketuner-egb16a)
i agree, the bushings and brackets that come with the blox are crap. when i replaced my bushings i got 21mm Energy Suspenion bushings/brackets from Summit. IIRC its not specifically listed for the car, but a universal 21mm bracket/bushing instead.
as seen here
Old May 4, 2006 | 09:35 PM
Default Re: 22mm bushing with 21mm bar (Voyage34)
**** I picked up the 22mm from pepboys, know that I know that 21mm can be ordered I'll exchange them for some 21s.
Old May 5, 2006 | 02:59 PM
Went back and exchanged them for some 21s, they were a special order so I can't install the bar for about a week but then I'll do a write up on it.
JMZ400
Oct 17, 2018 11:47 AM
96romaEK
Suspension & Brakes
26
Apr 16, 2010 03:25 PM
CALC!_JUST_du_IT!
Suspension & Brakes
Aug 28, 2007 12:27 PM
gubo22
Sep 3, 2003 12:57 AM
mingchi69
Aug 11, 2003 04:01 PM
