tech question. brake lamp?
Old May 4, 2006 | 04:38 PM
lude-tec's Avatar
Default tech question. brake lamp?
hi i know this is a newb question but i bought my car without a manual so i cant look it up. well i have a 4th gen prelude and the "brake lamp" light started going on 3 days ago. well im thinkin of bleeding the brakes but is this what the light indicates? i had this happened before and i replaced the brake pads and the light went off but now the pads are still pretty thick. so do you guys know what the light really indicates? thanks
Old May 4, 2006 | 04:42 PM
hella_usdm's Avatar
Default Re: tech question. brake lamp? (lude-tec)
it means one of your tail light brake bulbs is burnt out
Old May 4, 2006 | 04:44 PM
M2B4's Avatar
Default Re: tech question. brake lamp? (eluderman)
yeah lol dont go to the extreme of changing your brakes. its just a bulb.
Old May 4, 2006 | 05:44 PM
lude-tec's Avatar
lol ya i forgot to say that i checked my break lights to and all three of them works. thanks for looking out^^^. any other ideas?
Old May 4, 2006 | 07:52 PM
hella_usdm's Avatar
top off the brake fluid in the resivor. And check out the reverse lights too and the turn signal bulbs, they all fall under the "brake lamp" light.
Old May 5, 2006 | 06:41 AM
lude-tec's Avatar
i will do that. thanks bro
Old Jun 20, 2006 | 10:10 AM
Siegfried's Avatar
Default Re: (lude-tec)
I have the same problem, but my brake fluid is at max and all my bulbs(brake,reverse and turn signals) are ok, what else could it be ?
lude-tech, is your hand brake signal lighting too with the brake lamp ?
Old Jun 20, 2006 | 10:54 AM
JDMF22B's Avatar
Default Re: (Siegfried)
Actually, this problem is known to just be a prelude-comming-of-age problem. All lamps work, brakes are fine, but the light goes on. Mine did that as well. There seems to be some wiring problem when it comes to that light, because a LOT of people get that, with nothing wrong. ignore the light... at least its not a CEL
and i believe it is directly referring to one of (or both) tail brake lights
Old Jun 20, 2006 | 12:08 PM
NoVALude's Avatar
Default Re: (JDMF22B)
Don't know if this helps, but the third brakelight actually has (2) bulbs, so if it looks like one is working don't just assume that both lights are working. I did a visual test to see and had to take the cover off to actually see that one worked and one was burned out...
Good luck!
Old Jun 20, 2006 | 12:34 PM
EliTe 93Lude's Avatar
Brake light bulbs are double-sided. My suggestions:
1. Turn on your lights and see if the rear lights come on. If they do, try step two. If not, buy a new bulb.
2. Hit the brakes with the lights on. If the light intensifies and it's not your brake fluid or anything like that, it's most likely wiring.
Old Jun 22, 2006 | 04:48 PM
Siegfried's Avatar
Default Re: tech question. brake lamp? (EliTe 93Lude)
How could you check it comes from the brake fluid level sensor or the hand brake sensor ?
Could you just unplug these one by one to see if the brake lamp shut down ?
Old Jun 22, 2006 | 06:42 PM
JDMF22B's Avatar
Default Re: tech question. brake lamp? (Siegfried)
Yes pull the brake fluid with the car on! ;p *please realize this is sarcasm.*
Old Jun 22, 2006 | 08:09 PM
SKDRCR's Avatar
Default Re: tech question. brake lamp? (JDMF22B)
I believe there is a stop lamp switch behind the brake pedal that could be your problem if all of the lights are good.
Does the light come on when you start the car or only the after you push the
brake pedal?
If it's the latter of the two, I'm guessing the switch is your problem.
Old Jun 23, 2006 | 12:01 AM
Siegfried's Avatar
Default Re: tech question. brake lamp? (SKDRCR)
Nope, it's there when as I start the car, all bulbs fine, brake fluid full
nicolaselias
Dec 22, 2011 03:58 PM
bigleaguer34
Oct 20, 2009 08:53 AM
johnh22
Jul 25, 2005 07:24 AM
951dc5
Nov 18, 2004 02:42 PM
Starrman85
Jan 6, 2003 10:18 PM
