cruise control removal
Old May 4, 2006 | 04:00 PM
mattf22b1's Avatar
Default cruise control removal
Quick question with the cruise control throttle cable if i remove it from the intake manifold and take the rubber tubes off the right side of the manifold will this do anything to effect the car running?
these are the things i want to remove, everything else has been taken out. please respond asap as my cars sitting outside and its starting to get dark. thanks
Old May 4, 2006 | 04:13 PM
93acclude's Avatar
Default Re: cruise control removal (mattf22b1)
Taking the cable off wont affect anything but you will need to plug the open vacuum line. Leaving it open may cause some problems.
Old May 4, 2006 | 04:37 PM
shadow_ridge's Avatar
Default Re: cruise control removal (93acclude)
seems like a 5gen motor. I been wanting to this to my 6gen for years. When i bought my car my cruise control never worked, so pulled the swtich out and put a aftermarket one for my fog lights. If I remove the whole system, will it cause a CEL ?
Old May 4, 2006 | 04:50 PM
93acclude's Avatar
Default Re: cruise control removal (shadow_ridge)
nope. The system is linked to the ecu but not in a manner that will cause a cel. Just remember to plug the vacuum line and you'll be good. I'm not positive about the 6th gens, but on the 4th gens you need to cut the cable to get it out.
Old May 4, 2006 | 05:31 PM
NAiL05's Avatar
Actually you dont need to cut the cable. You just pull the cable connected to the back of the accelerator pedal and twist that plastic part in the firewall from inside the engine bay, take off the two 10 mm bolts and it should come right off. And yes you gotta plug up that vacuum line and dont forget to disconnect the plug.
Old May 4, 2006 | 05:35 PM
mattf22b1's Avatar
Default Re: (NAiL05)
it worked thanks for all the help guys...the car runs fine no cel which is good. the only thing left is the compressor for my a/c which i did today too. ill post pics of everything and step by step instructions this is the same for 4th and 5th gens im not sure about the 6th gen.
Old Jun 15, 2006 | 03:13 PM
RDub's Avatar
Default Re: (mattf22b1)
I'm looking to do this too, for those of you that have done it, what did you use to plug the vacuum hole?
Old Jun 15, 2006 | 04:45 PM
khunt0012's Avatar
Meat Robot Invisible
Default Re: (RDub)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RDub &raquo;</TD></TR><TR><TD CLASS="quote">I'm looking to do this too, for those of you that have done it, what did you use to plug the vacuum hole?</TD></TR></TABLE>
Anything. If it's a rubber line, find a bolt that will plug it. If it's a solid line find somethign that will cap it, or add a rubber line and a bolt.
Old Jun 15, 2006 | 09:10 PM
momstaxi's Avatar
Default Re: (khunt0012)
kragen/autozone sell vaccum caps for like $3.00 for a pack, much more attractive than a vaccum line with a bolt/etc. stuck in it...
Old Jun 15, 2006 | 11:23 PM
RDub's Avatar
Default Re: (momstaxi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by momstaxi &raquo;</TD></TR><TR><TD CLASS="quote">kragen/autozone sell vaccum caps for like $3.00 for a pack, much more attractive than a vaccum line with a bolt/etc. stuck in it...</TD></TR></TABLE>
Thanks, thats more what I was looking for. I'll check that out for sure
Old May 26, 2011 | 08:42 AM
92cb7sk8er's Avatar
im trying to do the samething as you but i have a ? the cable that you cut was the one going into the fire wall right? i already have the vacuum line closed off the ony thing keeping it in my car is that cable im scared to cut it because i dont want me mess my car up so was that what you cut off?
Old May 26, 2011 | 02:39 PM
92cb7sk8er's Avatar
well i found my answer so if anyone needs help in doing this just ask
Old May 26, 2011 | 08:45 PM
Brownjd's Avatar
not to thread jack, but my cruise control doesnt work after my h22 swap...everything is hooked up and seems to be ok, could it be that the computer does not work the cruise control? obd2 to obd1 conversion with chipped p28
Old Aug 17, 2019 | 03:14 PM
Accordforlife's Avatar
So i got a question for you, I got a 96 accord and have taken the cruize control out, the cable, plugges the lines back to the intake manifold which ran only to the cruize control module, am i suppose to leave the vacuum accumulater hooked to the vacuum lines still? It all started cause my cars idle would surge up to 1500 to 1000 even then lower to were it would want to stall or when i gave it a little gas it would like to bog out, even started back firing. So i replaced spark plugs, spark plug wires, hoses, fuel injectors, i replaced all the internal pieces of my dizzy, the intake manifold gaskets, throttle body and the gasket, the valve cover gasket, then swapped a identical top part of intake manifold that came with the throttle body i got off of a buddy, and all the codes my engine was throwing all went away, so i dont have any check engine lights on and my car starts and i can kinda drive it forward and backwards but its still idles slightly off as if theres a vacuum leak and ive gone over everything several times plus replaced hoses, and the only thing thats seems off to me is that theres a hissing noise as if its pulling in air when its not supposed to as its idling in park, i don't know if i gotta take the throttle body off and clean it again, maybe the butterfly valve isn't shutting all the way. Maybe i just didnt read the vacuum line diagram correctly and have them plugged in on the wrong spot for the evap and air/ fuel pressure. I'm stumped so if anyone could give me some advise or if has the same car toss a picture on here of the correct vacuum hose set up for all that, I'd be very appreciative of it
TheCivicMafia
Jun 14, 2012 01:55 PM
Devious951
Oct 20, 2008 09:11 PM
Turbo_honda
Jun 22, 2006 05:00 PM
NBPcivic07
May 11, 2004 11:38 AM
Greyout
Apr 16, 2002 10:02 PM
