Will Stock Civic wheels fit over GSR front/rear brakes?
Old May 4, 2006 | 03:37 PM
Sketch_hs's Avatar
Default Will Stock Civic wheels fit over GSR front/rear brakes?
my buddy has a 94 delslow s and wants to upgrade the front brake to integra GSR fronts. He has stock wheels.
will they fit?
Old May 4, 2006 | 06:51 PM
BOOSTED RIVAL's Avatar
Default Re: Will Stock Civic wheels fit over GSR front/rear brakes? (Sketch_hs)
If the rims is 14 inches or up it will fit no problem, but if it 13 inches the front will not fit because of the caliber is bigger but the back fit with no problem.
Old May 4, 2006 | 06:53 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Will Stock Civic wheels fit over GSR front/rear brakes? (BOOSTED RIVIL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTED RIVIL &raquo;</TD></TR><TR><TD CLASS="quote">If the rims is 14 inches or up it will fit no problem, but if it 13 inches the front will not fit because of the caliber is bigger but the back fit with no problem.</TD></TR></TABLE>
Not true. Some people end up having to put wheel spacers with their 14" wheels or grind off the calipers a little when they put 14s on GSR/Ex ABS/Si brakes
Which "Stock Civic wheels" are you talking about exactly. They range from 13" to 15" (17 if you include 2006 )
Old May 4, 2006 | 06:56 PM
Default Re: Will Stock Civic wheels fit over GSR front/rear brakes? (SkoundrelUSA)
My bad then because I have put 14 inche steelie on my integra with no problem.
Old May 4, 2006 | 08:10 PM
Sketch_hs's Avatar
94 delsol s like i said in the OP
Old May 4, 2006 | 08:29 PM
skip.two's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">Not true. Some people end up having to put wheel spacers with their 14" wheels or grind off the calipers a little when they put 14s on GSR/Ex ABS/Si brakes</TD></TR></TABLE>
this only applies to the 14" HX rims.
the 13" steelies on your friends Del Sol S won't fit.
Old May 4, 2006 | 09:59 PM
Targa250R's Avatar
be professional
Default Re: Will Stock Civic wheels fit over GSR front/rear brakes? (skip.two)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skip.two &raquo;</TD></TR><TR><TD CLASS="quote">the 13" steelies on your friends Del Sol S won't fit.</TD></TR></TABLE>
2-7offsuit
26
Aug 30, 2005 08:43 AM
usdmcivic94
Oct 17, 2004 04:20 PM
b18c1-ek
Feb 14, 2002 10:13 PM
Chugger
Oct 8, 2001 03:36 AM
