I need cooling advice/help for my DA teg
Old May 4, 2006 | 10:25 AM
Alex_G's Avatar
Occupy GDD
Default I need cooling advice/help for my DA teg
Well I finished the b20 swap in my 92 teg and decided to take it for a spin. I let it warm up for about 10 mins and before I drove off, I didn't see any overheating during that time (hood was open) until I took down the street (I only drove it to the stop sign and back to the driveway).
Well I turned it off, popped the hood, and saw that antifreeze seemed as if it was trying to rush out of the cap. I think it overheated because the fans weren't turning on. Could it also be a stuck thermostat?
Well since summer is comming fast I want to go ahead and replace my current cooling sytem with a new radiator, fans, and a thermostat. My question is what do you guys recommend? I've been looking and sites and i've seen different brands such as Fluidyne, Koyo, and C&R radiators and need some advice as to which one to go with. I also want to buy new "performance" fans (something better than stock) and dont' know which ones to go with. Also, I'm not running a/c if that matters.
Any help guys is much appreciated thanks!
Old May 4, 2006 | 10:49 AM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: I need cooling advice/help for my DA teg (Alex_G)
Radiator off ebay and some fans from B18bturbo. New thermostat with some 50/50 mix and a bottle of water wetter should fix your problem.
Old May 4, 2006 | 11:00 AM
Alex_G's Avatar
Occupy GDD
Default Re: I need cooling advice/help for my DA teg (00IntegrAllmotoR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">Radiator off ebay and some fans from B18bturbo. New thermostat with some 50/50 mix and a bottle of water wetter should fix your problem.</TD></TR></TABLE>
Hey thanks those fans are a good deal.
Home Wrecker
Mar 29, 2006 12:58 PM
tuyettam
Oct 19, 2005 02:56 AM
4doorB18Bcivic
Jul 6, 2003 10:07 AM
X2BOARD
Apr 10, 2003 07:05 AM
mr_mbuna
Dec 5, 2002 03:13 PM
