Did Search: Where is Scanner Port for 95 GSR?
Old May 4, 2006 | 10:11 AM
KArowd's Avatar
Default Did Search: Where is Scanner Port for 95 GSR?
hi there, was looking to run my gsr on a scanner but couldnt find the port. I thought it was underneath the driverside but i could not find it there? It was on my LS but not on the GSR. if anyone can help me out with this, i would really appreciate it. thanks a lot<3
Old May 4, 2006 | 10:16 AM
Racermech's Avatar
Default Re: Did Search: Where is Scanner Port for 95 GSR? (DOughh)
My 96LS is on the center console, passanger side all the way at the back.
Old May 4, 2006 | 10:17 AM
KArowd's Avatar
For a gsr tho:X
Old May 4, 2006 | 10:55 AM
DC4_MADMAN's Avatar
Default Re: (DOughh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOughh &raquo;</TD></TR><TR><TD CLASS="quote">For a gsr tho:X</TD></TR></TABLE>
95's are OBD1, no scanner port. Probably why you cant find it.
Old May 4, 2006 | 11:04 AM
KArowd's Avatar
So how is it possible to find problems. Im asking this because my check engine light has been coming on lately. So i wanted to do a scan for it.
Old May 4, 2006 | 11:06 AM
DC4_MADMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOughh &raquo;</TD></TR><TR><TD CLASS="quote">So how is it possible to find problems. Im asking this because my check engine light has been coming on lately. So i wanted to do a scan for it.</TD></TR></TABLE>
Key on\Key off test, thats how it done with the OBD1.
Woohoo, I rhymed.
Old May 4, 2006 | 11:10 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (4door_demon)
You also need to stick a wire/paper clip in the one plug near the ecu.
Old May 4, 2006 | 11:56 AM
Ichigo's Avatar
Default Re: Did Search: Where is Scanner Port for 95 GSR? (Racermech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">My 96LS is on the center console, passanger side all the way at the back.</TD></TR></TABLE>
Same with Gsr obd2 also.
Old May 4, 2006 | 12:57 PM
Acurazor's Avatar
damn no body seemed to help you. Since it's OBD 1 you need to jump the harness, which is above the ecu. Reach under the glove box and pull the plug out, the one with only 2 wired in it. Jump it with a paper clip, turn ignition 2 on and read the code. It's really easy obd1&gt;obd2
Old May 4, 2006 | 09:28 PM
263DSP's Avatar
if your car is a 95 it is OBD1, which means there is no scanner port. you can get code from the ECU, but i can't remember right now. I will have to get back to you about that.
overrev130
Jun 12, 2008 08:54 AM
njcgsr
Feb 16, 2008 09:41 PM
renarudo
Jul 14, 2005 06:53 AM
GS8HFL21
Mar 22, 2004 03:36 PM
Honda_RN
Oct 17, 2003 01:19 PM
