CRx dx rear sway bar?
hi ive tried searcing and only came up with a few results and none were exactly what i was looking for. I basically want to know if there are any rear sway bars for my 89 dx that will bolt up like or similar to the stock oem si sway bar that will allow me to have a lower bottom strut brace. I have a progress rear sway bar but it bolts in place of where the lower strut brace would go. Ive seen pics of some crx's on here running sway bars and lower strut braces for the rear. If anyone has some suggestions i would appreciate the input.
you can get the suspension techniques rear swaybar. it has its own brackets, you dont even need Si rear control arms.
ASR has a reinforcement plate and swaybar as a single assembly as well.
if you get the si rear control arms with the swaybar anchor holes, you can custom fabricate the stock swaybar bracket to work.
https://honda-tech.com/zerothread?id=1146145
i have the function 7 lower control arms. So if i can get a crx si rear sway bar with all the hardware i should be able to modify the brackets to fit my chassis? Does the ST sway bar allow the use of lets say a skunk2 lower strut brace or any other one for that matter? I looked for the asr brace for a crx but i couldn't find one.
crx4luke
Nov 9, 2006 05:24 PM
