EG Center Console Problems
Old May 4, 2006 | 08:15 AM
HBADGE's Avatar
Default EG Center Console Problems
EDIT: Made a mistake in title. I meant to say dash.
The center vents/blowers arent working at all. Left and right sides are fine, what could be the problem here?
Old May 4, 2006 | 09:35 AM
eg8civic93's Avatar
Default Re: EG Center Console Problems (HBADGE)
Did you check to see if the vents were closed?......this could be done manually, or if its broken, it could be closed.
Old May 4, 2006 | 10:08 AM
ZipTieGUy's Avatar
same problem here but i dont really care about it
Old May 4, 2006 | 11:28 PM
HBADGE's Avatar
Default Re: (ZipTieGUy)
No theyre open alright..
Old May 5, 2006 | 06:10 AM
qat727's Avatar
Default Re: (HBADGE)
is there any air blowing out of the one at the top of the dash?
Old May 5, 2006 | 09:00 AM
HBADGE's Avatar
Default Re: (qat727)
none..
Old May 6, 2006 | 12:20 AM
qat727's Avatar
That's quite odd... If all the circuits are working right, then you shouldn't have that happen. First few things I'd check before tearing it apart would be:
the diverter valve thing on the top of the dash. Does it move, does it make a difference, and can you tell if it is moving anything when you move it?
Do each of the buttons on the HVAC control head do something? Can you hear the valves moving inside the blower housing, or does it not make any noise?
See if you can narrow it down a bit more. It's possible that some of the internal valves got messed up.
mister_ej2
13
Apr 8, 2008 11:32 AM
Lmgrcivic
Sep 5, 2007 05:46 PM
ZakkWylde
May 24, 2007 05:18 AM
lilred92hatch
Mar 24, 2002 08:32 PM
