sell price? would you buy it?
ok i have a 1990 honda accord EX. i see these cars uaslly selling for around $1500-$2500, ill be selling mince for $950 or best offer, heres the list of problems it has: needs window replaced, sunroof, need replace, revieiw mirror need replace, front end a lil messed up from accident but not very noticeable, covered with front end mask which is acutally pretty nice, nice stuf it has: $80 front speakers upgrade, no rear speakers, great paint shines, transmsion and engine in excellent condition!, aftermaket cold air intake installed. accelaerates faster than normal honda accord. new performance spark plugs, all leather seats. what would pay?
Which window needs replacing?
How many miles? Stock engine and trasnsmission? 5spd or auto?
It's hard to say without some more info and pictures.
how did you get a CAI into your accord where did you put it did you relocate the battery just wondering cause it dont look like there is enough room to put one in only enough for a short ram
don't you have a hole next to your battery that leads to an area just between the bumper and wheel well splash guard? Thats how my 95 EX was, I haven't looked at a 90-93 Accord but I would assume it's pretty similar.
well yha there is but it dont look big enough for the pipe but i could be wrong but then theres the filter and that dont look like it would fit eather at least not in my friends 92 accord there is no room for anything
yeah, there's only room for the pipe. You have to put the filter on from under.
You just need to remove part of the splash shield to have enough access to put the filter on. If your pipe is two pieces, you may be able to connect the filter to the bottom pipe and then feed the bottom pipe from under the hole up to the other pipe and then connect the two pipes.
It's very simple to do.
yea it sounds simple to do i had to drimil the hole to make it big enough for the pipe to fit through it tool a long time as i recall but it was worth it, it has stock engine and trans, front winshield needs replacing, side mirror replace, sunroof window replace, driver side window regulator bad. 230000 miles automatic SOLD for $750 at that price seems like a ripoff but you gotta understand that the trans and engine being in tip top shape is worth 750 anyway not too metion its in a running car with pretty much new tires, yes it needs alot of body work which you can only tell by looking up close. runs flawlessly. i woulkd deffinatley keep it if it where not for that dent in the front. i had huge plans for that car... 17 inch rims, tinted windows, expensive sound system, projector lights the works but since that accident i lost my zeal and didnt feel like shelling out 1000+ just to get it back to stock, and all my friends are upgrading to newer cars so i decieded its time i upgraded to a newer looking car.
ChapR
Dec 30, 2002 10:11 AM
